Routing with arcpy
1097
12-16-2011 01:43 AM
ChristinaMitsakou
I'm writing a script with arcpy that should define the routes between couples of origin/destination points. The "Add the Traversal results ..." button of the Network Analyst seem not to work with arcpy.
Is there any way that I can find the paths via scripting in order to automate the process?
JaySandhu
Unfortunately there is no way to call that .net addin button from arcpy. For 10.1 we have added a new GP tool called Copy Traversed Source Features and that can then be called from arcpy. You can consider joining the beta program for 10.1 if you need to use that functionality.
Jay Sandhu
