Route Analysis - Is it possible to get travel times for multiple routes at once?
1323
01-19-2022 01:12 PM
Sean_Wray
In the Service Area analysis it is possible to set multiple locations and solve for the service area based on time for each of the locations at the same time. The process only has to be run once.
In route analysis, is it possible to set up stop A and stop B as a pair, then set stop C and stop D as a pair and then solve both for travel time in one process?
MelindaMorang
Yes. You simply need to set the RouteName field in the input Stops so that each pair has a unique value.
MelindaMorang
MelindaMorang
Hello Sean and anyone else reading this thread who might be doing similar workflows.
Esri’s Network Analyst Team is doing some research about customer workflows involving solving routes or calculating travel times and distances between known or preassigned pairs of origins and destinations.  It sounds like that's what you're doing here!  We’d like to better understand our customers’ needs in this area and may use this information to design and develop improved tools and workflows.
If you have a few minutes and are willing, could you please fill out the attached survey and return it to the e-mail address included inside the document?  Alternatively, you can reach out to me (my e-mail address is in the document) to set up a meeting.
Thank you so much!!
