"Dissolve Network" stuck
4576
11-11-2015 10:08 AM
GustavoCordero
Arcgis'm using 10.3, I need Dissolve Network Dataset
but it remains stuck, the only mesaje that I can see this this
"Creating spatial grid default values"
I do not know what I should do
the process takes more day
DanPatterson_Retired
Well after a day, I suspect it isn't going to happen...or it happened and you will be the last to know.
  • How big was the network?
  • How disjointed was it?
  • did the network work before this action?
  • Have you tried the operation on a smallish subsection?
  • Is it on a local machine or on some network thing?
Any other details would help
GustavoCordero
Greetings friend thanks for replying
How big was the network? is not very big, I just run another system of another country with uch more records and I had no problem
the network is working when perfectly before making "Dissolve"
I'm running on my machine locally
Make a backup of the file, and run a check geometry if applicable to your file type.  Select a small area and try it, there could be an issue with a portion of the file.  Also, on those rare occasions when ArcMap goes unresponsive, I find a full shutdown, quick coffee, a reboot and restart sometimes works wonders. If done at the end of the day and it works...you feel good...if it doesn't work...you go home and try it again tomorrow
AsafBen-Ari
Hi Gustavo,
In the past I had the same problem. It solved only after I changed the values in the driving direction field to upper case (ft --> FT ; tf --> TF).
You might have a similar problem in your data as well.
Asaf.
