Polygon Barrier for Service Area
3762
09-05-2014 09:51 AM
ISP_graynic
Does anyone know if it possible to generate polygon barrier for a service area using Network Analyst?  I've created a polygon barrier that works when creating a new route using Network Analyst, but the service area polygon that is generated is not affected by the barrier.  I have the barrier has a restriction so shouldn't the barrier keep the service area polygon from entering into it?
Any help is greatly appreciated!
ISP_graynic
I contacted ESRI and figured out the problem.  All I needed to do was turn off "Use Hierarchy" which generalized the polygons, as well as changing the polygon generation to "Detailed" instead of the default "Generalized".
ISP_graynic
It looks like the polygon barrier does affect the service area, but not completely.  Some of the service area still bleeds over into the polygon barrier.
I've attached a screenshot to show this.
ISP_graynic
