So it sounds like you can solve the route but need to analyze the results more.
One way can be to spatially select all the roads that overlap your route and then summarize them and the other can be to add the "traversal" results being stored in memory as a feature class to ArcMap and summarize them. The traversal results has every edge of the route with its network attributes. You can use the following link to see how to access the traversal result:
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#//000100000245000000
Jay Sandhu
Jay Sandhu
Public Sub AddNATraversalResultToArcMap() Dim pMxDoc As IMxDocument Dim pNetworkAnalystExtension As INetworkAnalystExtension Dim pNALayer As INALayer Dim pFLayer As IFeatureLayer Dim pTraversalResultQuery As INATraversalResultQuery Dim pNATraversalResultEdit As INATraversalResultEdit Set pMxDoc = ThisDocument Set pNetworkAnalystExtension = Application.FindExtensionByName("Network Analyst") Set pNALayer = pNetworkAnalystExtension.NAWindow.ActiveAnalysis Set pTraversalResultQuery = pNALayer.Context.Result Set pNATraversalResultEdit = pTraversalResultQuery 'Infer Geometry pNATraversalResultEdit.InferGeometry "", Nothing, New CancelTracker 'Get the Edges and add as a layer Set pFLayer = New FeatureLayer Set pFLayer.FeatureClass = pTraversalResultQuery.FeatureClass(esriNETEdge) pFLayer.Name = pFLayer.FeatureClass.AliasName pMxDoc.FocusMap.AddLayer pFLayer 'Get the Junctions and add as a layer Set pFLayer = New FeatureLayer Set pFLayer.FeatureClass = pTraversalResultQuery.FeatureClass(esriNETJunction) pFLayer.Name = pFLayer.FeatureClass.AliasName pMxDoc.FocusMap.AddLayer pFLayer End Sub
