Network Dataset & Traffic Data
1247
12-07-2022 09:40 AM
LuisCalderonUY
I am working on a network dataset with historical traffic data, and I have some doubts:
1) Are changes in historical data taken into account when rebuilding the network dataset?
2) In case they are not considered, is it necessary to disarm and reassemble the network dataset from scratch?
I'm using ArcMap 10.8.2 and ArcGIS Pro 3.
Thanks in advanced !!!
AlanHatakeyama
Hi @LuisCalderonUY,
If you make edits to the contents of the Profiles table, then these changes are reflected in your next network analyses after you have saved your edits.  If you make edits to the contents of the Streets-Profiles table, then you will need to rebuild your network dataset prior to performing any new network analyses to reflect the change.  For either case, it should not be necessary for you to delete the network dataset and re-create it from scratch.
If this behavior is not what you are seeing, then please contact Esri Support so that they can investigate this in further detail.
Thanks!
Alan Hatakeyama
