Network Analyst
2983
10-06-2009 10:39 AM
JaySandhu
Original Post Date: Oct 06, 2009 11:39 AM PDT
The Network Analyst in 9.4 has a lot of new functionality. Let us know your experiences in using it!
Jay Sandhu
JaySandhu
In 9.4 the Network Analyst has been updated with a number of new features and numerous enhancements. The new features are:
A new Location-Allocation solver for site selection including support for gravity (Huff) models
Enhanced barrier support for using line and polygon barriers
Lot of enhancements to the Network Dataset such as:
  • Incremental Rebuild based on dirty areas
  • 3-D Network connectivity
  • Versioned network datasets in SDE
  • Historical traffic Data
  • Dissolve network tool for networks in a geodatabase with support for hyper edges to enable high-performance routing
  • Better storage of network elements on disk in the network dataset to support faster routing performance
Numerous other improvements such as in loading locations, better no u-turn support, driving directions, geoprocessing, scalability, SDK, Tutorials and documentation.
Jay Sandhu
NiallCarter
HI
The help for multiple breaks specifies that each route can have 'at most one breal' although I was under the impression that multiple breaks was a new feature of 9.4?
Each time I try to add another break into the VRP the solve fails. Any clues?
Another new function - that of the ability to leave the start or end location empty - is advirtised to be included at 9.4. Again when I try to leave either of these values blank my VRP solver fails. Any ideas?
Niall Carter
NaAn
Hi Niall,
ESRI will introduce the multiple breaks function in 9.4 beta 2 which will be released in late January. With the new function, user will be able to add up to 5 breaks.
Virtual depot function was introduced in 9.3.  User is allowed to leave EITHER �??StartDepotName�?� OR �??EndDepotName�?� blank for a route, but not both. It should work well. Could you please let me know what warning/error message you got?
Thanks.
Anna
NiallCarter
Hi Anna
Apologies since re running my analysis I have managed to get the VRP with either start or end depots as null to now work.
I will wait for beta 2 before testing the multiple breaks. Is there a doc somewhere which indicates which functionality is contained in beta 1 versus beta 2? Clearly I was not aware that multiple breaks came in the full function beta 2 release.
Ta,
Niall
