Network Analyst - Route
1716
06-22-2023 07:18 PM
temprobertcottreau131313
Is it possible to add a letter (non-numerical) suffix to a stop sequence in a Network Analyst route?  Not to every stop in the sequence but only 1 or two per route.
I'm not sure this is possible.
I'd need to create a new text field and do it manually.
MelindaMorang
The Route Stops Sequence field is a long integer, so you can't add a letter to it.  Can you explain what you're trying to do?  Maybe we can come up with some better way to do it.
