Network analyst in the 3D
3539
6
11-09-2012 03:37 AM
AlesgerMammedov1
Good day.
I am learning application Network analyst in the 3D.
I saw expression [SLength] / (3 * 26.8224)
I want to ask you, what does it mean this number 26.8224 in this expression ?
Please help me. It is very important to me.
JaySandhu
Looks like an expression to set up walk times.
That number, 26.8224 is the number of meters you can walk in 1 minutes if you are walking at a rate of 1 mile per hour.
That is, one mile is 1609.34 meters and then divide by 60 will give you 26.8224
So the expression  [SLength] / (3 * 26.8224)
is calculating the walk time if you can walk 3 miles an hour where the SLength happens to be in meters.
Jay Sandhu
AlesgerMammedov1
Thank you very much for you answer.
Now i have next question for you.
Can i use tihis expession  [SLength]*60/3000 in this analyses
Where 3000 is pedestrian walks 3km/h
Best Regards
Alesger
RamB
yes, you can use speeds from 2.5 to 4 km/hr.  the 1 mile/hr seems to me is for a crowded area.
regards
JaySandhu
regards
The previous expression was 3 miles per hour and NOT 1 mile per hour. Note it was multipled by 3.
Jay
JaySandhu
Best Regards
Alesger
The expression is fine. But as Srirama pointed out, 3 Km / hour may be slow unless you know that is the speed at which your pedestrians are walking. Normal walking is 3 miles an hour or 4.8 Km per hour. So you could change the 3000 to 4800.
Jay Sandhu
AlesgerMammedov1
Thanks a lot
Regards
Alesger
