Network Analyst Error "Build Network Dataset failed.  File read/write error occurred"
2575
12-29-2010 01:02 PM
MaxBolen
I'm using Street Map 9.3 street network clipped down to my study area.  When I try to build the network dataset I receive the error "Build Network Dataset failed.  File read/write error occurred".  I have deactivated my virus protection, as I read that this can be the problem, no luck.  I have full permissions on my machine and network, and I have tried moving data locally with no success.  If I go into the file properties and un-check read only it just appears to be checked again after I reopen the properties.  I have also tried on others computers with no success.  I'm running Win 7 64bit, nos SDE or other products.  Anyone have an idea?
