nax Module addFields Method
1126
05-12-2024 12:43 PM
TimSemmelhaack
I Want to add an extra field to the routes layer in a Vehicle Routing Problem Layer created by the nax module. But I can't figure out, what is the right syntax for the field_description.
vrp.addFields(arcpy.nax.VehicleRoutingProblemInputDataType2.Routes, ["new_field","FLOAT",""])
This doesn't work
DanPatterson
MVP Esteemed Contributor
few examples, but a list of lists perhaps
Set analysis inputs—ArcGIS Pro | Documentation
# Add a custom field called NumTrucks to the Service Area Facilities input class
field_definitions = [["NumTrucks", "SHORT"]]
service_area.addFields(arcpy.nax.ServiceAreaInputDataType.Facilities, field_definitions)
... sort of retired...
DanPatterson
