Multimodal Network Analysis
411
10-21-2011 05:23 AM
CameronManche
Hello,
I would like to create a multimodal network. I have created two closest facilities: the first one has the distance patients travel to facility X, the second has the distance patients travel from facility Y to a hospital. What is the most time effective way to calculate the distance between X and the closest Y facility?
Thank you,
CManche
JaySandhu
It is not clear from your post what you want to accomplish. A multimodal network is a dataset that combines different modes of travel such as rail, bus, bike, pedestrian and car. It has nothing to do with closest facility. Once you have a network on which you want to travel on, you create a closest facility layer and load in your facilities and incidents and solve to compute the distances between them. So if I uderstand your question, you want to compute distances from facilities set  X and set Y, then load them into the closest facility layer and solve. If you want to find the distance between one X and one Y then use the Route solver.
Jay Sandhu
CameronManche
Thank you for your help. I'll be sure to utilize route solver.
RamB
Occasional Contributor III
The question probably meant to find closest facility on a multimodal network ? Nevertheless, it is good that this question is now answered 🙂
