make network analyst propose new (not existing) facilities?
1200
06-09-2010 08:10 AM
ToreBorvik
I'm quite new to network analyst.
I have a model with some thousands demand points and about 15 facilities.
The model finds out how many % of the demand points that can reach a facility in X minutes.
But I want to know if network analyst can suggest new points as proposed facilities which meet the demands I set. (since with the existing facilities I have, the % demands are not met)
running: arcinfo10
I've considered a possible solution by generating lots of evenly spaced points and use them as facilities in the analysis, but the processing would take too long...
JaySandhu
In ArcGIS 10 Network Analyst has a new solver called Location-Allocation. You can use it to find "new" facilities to serve a set of given demand. You can load in the existing demand locations as demand points, existing facilities as "required" facilities and a set of points that you can open new or "candidate" facilities and solve solve for how many you want. Their are numerous options and goals you can set. I suggest you run through the new tutorial for location-allocation and read up on the help to use this new solver effectively.
Regards,
Jay Sandhu
ToreBorvik
thanks a lot!
