Is there a Travel Mode property equivalent to Accumulate Attribute?
1001
08-12-2020 05:37 AM
jacquelinewillan1
In 10.6, the Make Route Layer command had a property "accumulate_attribute_name" where for each cost attribute that was accumulated, a Total_[Impedance] property was added to the routes that are output . In Pro, is there a property in TravelMode that is equivalent to that property? Thanks!
MelindaMorang
No, the accumulate attributes are independent from the travel mode.
jacquelinewillan1
OK, in that case where should they be input for the solve with the NAX module?  I have the code:
arcpy.nax.MakeNetworkDatasetLayer(NDS, NDLayerName)
route = arcpy.nax.Route(NDLayerName)
route.load(arcpy.nax.RouteInputDataType.Stops, Waypoints)
result = route.solve()
I didn't see them as a RouteInputDataType in the documentation and didn't see where else they could be input?  Thanks!
MelindaMorang
Just set the accumulateAttributeNames property of the Route object, the same way you would set the travel mode.  The complete list of properties can be found here: Route—ArcGIS Pro | Documentation
jacquelinewillan1
That's great! don't know how I missed that.  Thanks for your help!
