How to get create Route-Stops with ModelBuilder?
3094
03-24-2011 07:50 AM
Stefan_Arndt
i would like to solve a route in a network dataset as a part of a process in the model builder.
The problem is that i dont know how to create the `Network Location Tools` (--> Stops of the Route) within the ModelBuilder.
Additionally the problem is a little bit more complex:
I have Geocoded Points in a Database Table. This Points should be the Stops (Start, Stops, End) of my Route.
So i think i need a kind of script, which takes the points in a loop and add them as stops into my network, before i can solve it. All of this inside the Model ...
Is this possible or only a dream? 🙂
Best regards,
Stefan
JaySandhu
You can use the Add Locations tool to load "stops" into a route analysis layer.
I will suggest that you look at the tutorial on how to do route analysis with mode builder here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Exercise_6_Creating_a_model_for_route_...
Regards,
Jay Sandhu
