Help C# needed Convert Line to Points
1355
07-13-2011 02:48 PM
BaluRamki
Hey Guys ,
I'm Dead Duck in The Ocean....
I need to convert route output of the analysis to points for use outside of gis ...
I have no idea if it is possible though found a old website which had tools for GIS9.2... that had convert line to point tool.....
I'm using GIS 9.3 Vstudio2008......(C#)....
I GREATLY APPRECIATE YOUR HELP......
PatrickStevens
Hello!
Route geometry is in the form of a Polyline, which can be cast as an IPointCollection.  Use the EnumVertices property to get an IEnumVertex that you can use to iterate over the vertices associated with a polyline.
Working with IEnumVertex
Good luck!
BaluRamki
Hello!
Good luck!
Thank you Sir.
I just started learning programming  and also GIS for my Research I'll try what you suggested and I'll Post on my results
Thanks a Bunch
