Finding a desired distance down a line
3132
02-06-2014 06:14 AM
RobertBorchert
Honored Contributor
I am new to Network Analyst.  I have worked a lot with Geometric Networks.
I am on 10.2 and have all extensions available to me.
Here is what we are trying to do.
We have transmission lines.  We have SCADA points on those lines.
What we would like to do is trace downstream from a given SCADA point a given distance.
example.  SCADA point ABC I want to select it and then find a point 1453 feet away on a given transmission line.
Can anyone direct me to a tutorial or give me a rough sketch on how to accomplish this.
I have created a Route Layer out of my transmission lines and assigned a RouteIdentifier.
Do I need a geometric network, a network dataset etc...
thanks,
RamB
may be use dynamic segmentation of linear referencing feature of arcgis.
http://resources.arcgis.com/en/help/main/10.2/index.html#//003900000001000000
RobertBorchert
Honored Contributor
thanks I will give this a look.
However it sparked an idea in me that we could simply assign address ranges in the transmission line from the SCADA point out and geocode the locations.
But the quick look I took at the linear referencing looks promising.
nicogis
In GN if you have set flow with sink you can perform a task downstream trace and find a valid solution. Then with IEnumNetEID you build a polylineM (MAware) and with IMSegmentation3 Interface you calibrate M value and find the point to distance ...
nicogis
or more simply, use QueryPoinAndDistance (see ArcObjects 10 .NET SDK Help )
