Export route .grf file from Network Analyst
3402
05-21-2010 03:33 AM
AntónioMarques
I would like to know how to export .grf files using Network Analyst. I 've read there is a tool that can be add to Network Analyst's toolbar, I believe is called "Navigation Export tool" but i don´t understand if it's meant to be used only in ArcLogistics or does it work also in Network Analyst.
Any suggestion? 🙂
Thanks!!
António
JeffWickstrom
Hello António,
Here is a C# class (source code) attached which is at least a start for you.  It exports Route Stops, but no line geometry as the latest ArcLogistics Navigator now supports.  The .grf file specification is included with ArcLogistics Navigator.
Jeff
AntónioMarques
Hello António,
Jeff
Thanks, Jeff!
I thought that it may exist some tool that could allow a system where you create routes in ArcGIS Desktop using Network Analyst and then use those routes for driver directions in devices with ArcLogistics Navigator.
I will try to use that source code and see what i can get of it! 🙂
Regards,
António
