ESRI StreetMap network dataset error
3468
10-25-2010 06:53 AM
by Anonymous User
Not applicable
Hi!
i've downloaded and extracted the three sets of data from the ESRI Data & Maps to my machine to do some Network Analyst testing, however, i get errors when i try to pull the 'streets' SDE Network Dataset into ArcMap (10).  (Error opening network dataset and 'Could not add the specified data object to the map.')
Does anyone know what's going on?
thanks!!!
by Anonymous User
Not applicable
figured it out!
when you download the three iso files & extract them, the streets.sdc & ,xml files need to be moved into the 'Data' folder...
JustinHampton1
Thanks for this.  This also solved my issue.
BethManghi
This was very useful for me too!  I guess it helps to actually read the readme file!
AaronCole
Lifesaver, thanks!!!!!
