OD Cost Issue
1189
11-30-2011 11:41 AM
MaulikVaishnav
I have created a network dataset and am trying to calculate network distances from multiple origins to one destination. For most instances, the OD Cost Solve fails and the error message states that no destinations were found for the origin points (even if the snap tool is used to locate points on the network). Any help on this issue would be great!
Maulik
JaySandhu
Since the error message states that no destinations were found for the origin points that means you have connectivity issues with your network. These can be due to topology problems with the data, restrictions, barriers or unpopulated impedance attributes. Have you tried running a Route between two locations to see if you can find a path? What is the source of your network?
Jay Sandhu
