Error Running Generate Service Areas Tool
1193
04-16-2021 08:44 AM
by Anonymous User
Not applicable
I created a custom geoprocessing tool in arcpy in ArcGIS Pro. In this I use the Generate Service Areas tool. This works as expected in Pro, but when I upload to an ArcGIS Server and try to run it in a web app in AGOL it fails. Here is a snippet of code from the script:
tbx = "https://logistics.arcgis.com/arcgis/services;World/ServiceAreas;username;password"
arcpy.ImportToolbox(tbx)
arcpy.AddToolbox(tbx)
result = arcpy.GenerateServiceAreas_ServiceAreas(facilities, breakValues, breakUnits)
while result.status < 4:
    time.sleep(1)
result_severity = result.maxSeverity
if result_severity == 2:
    arcpy.AddError("An error occured when running the tool")
    arcpy.AddError(result.getMessages(2))
    sys.exit(2)
elif result_severity == 1:
    arcpy.AddWarning("Warnings were returned when running the tool")
    arcpy.AddWarning(result.getMessages(1))
result.getOutput(0).save(serviceArea)
Any ideas on what could cause this to fail or a workaround?
DanPatterson
MVP Esteemed Contributor
Is that the exact code used in both environments?
What was the error message?
AddToolbox and ImportToolbox are the same
AddToolbox—ArcGIS Pro | Documentation
... sort of retired...
Max_Zeng
Hi, I am trying to understand more about your workflow. Do you want to run GenerateServiceAreas from your enterprise, which points to GenerateServiceAreas in ArcGIS Online? If that's the case, you can refer to this documentation to configure route utility service on your portal, to use ArcGIS Online routing services.
