Error: Cannot read from network table.
3626
06-04-2014 05:02 AM
fionasimpson
Hi
I am trying to run a very simple network analysis between 5 points and every time i do i get this error
"Error: Cannot read from network table."
I can't seem to find anything on what that actually means and what I have done wrong to fix it.
I have tried rebuilding my network and that has not helped.
Any help would be appreciated.
Thanks
Fiona
MelindaMorang
Hi Fiona.  Can you give us more details?  What type of network analysis are you doing (Route, Service Area, etc)?  Did you create the network dataset yourself?  Is it a file geodatabase network, shapefile, SDE, etc?  Can you post a screenshot of the error message?  All of these things will help us figure it out.
by Anonymous User
Not applicable
hey, i have the same problem. im doing a route, i create the network dataset
any help would be appreciated
Thanks
