Direction Arrows
13662
11
09-07-2011 08:46 AM
UchitPatel
I want to add manual direction arrows to street network. Is it possible without network analyst extention?
Thanks.
Uchit Patel
JamalNUMAN
Legendary Contributor
Thanks.
Uchit Patel
Hi uchit,
You can show the arrows temporary! use the command "copy parallel" (see the attached images). Unfortunately, the command provided by ET geoTools sounds not to do this without Network Analyst.
hope this helps
regards
Jamal
Jamal Numan
UchitPatel
Jamal,
When i go to editor menu Copy Parallel is disabled. Please help.
Thanks.
Uchit
JamalNUMAN
Jamal,
Thanks.
Uchit
Well, you need to select the features first!
Jamal Numan
UchitPatel
Jamal,
I have down loaded ET GeoTools 10. Now how can I use draw errows to show direction?
Thanks.
Uchit
JamalNUMAN
Jamal,
Thanks.
Uchit
Hi uchit,
to change the direction:
sure:
- show the arrows using the command (Draw arrows...)
- start editing
- double click the feature that you need change its direction
- right click
- choose Flip
- save the edits, this will reverse the direction.
did i answer your question?
regards
Jamal
Jamal Numan
UchitPatel
Thaks Jamal. It is working.
Uchit
UchitPatel
Jamal,
Last week it is working fine. Today all icons are disable except Draw vertices. I want to use Draw arrows...... . Please help me.
Uchit
JamalNUMAN
Jamal,
Uchit
neither mine! I think it is a license issue!
use the tool "copy parallel" to display permanently the direction!
ArcGIS should have this command as built in!!!!! we all need it
regards
Jamal
Jamal Numan
DarrenWiens2
Just FYI, you can add arrows to lines using ArcMap symbology if you dig deep enough into the properties (use a marker line symbol on top of a simple line symbol).
