Hello GISers,
I am attempting to create an Accessibility surface for the entire state of Florida. I have created a 6X6 mile grid of points over the state (from the create fishnet tool). For each grid centroid I created a 6 mile service area using Network Analyst. I also have extracted shopping opportunities from the statewide parcel dataset. For each six mile service area, I want to calculate an OD cost matrix from the grid point from which the service area was created to the shopping parcels whose centroids fall within the particular service area. I will then use an accessibility equation to calculate an accessibility value for each grid point based on the 6 mile serve area and interpolate over those values to create a continuous surface.
I have a decent amount of model builder experience and some python. In my head I know what I have to do (I believe). I must loop through the service area feature class one by one, select the parcels whose centroids fall within the particular service area and create the OD matrix from that selection. Is this possible? If so can I do this in model builder or will Python be a more appropriate avenue? I think if I am pointed in the right direction I can it done. Thanks so much. Let me know if you need any more clarification.
Russell Provost
Master's Student/Research Assistant
Department of Regional and Urban Planning/GeoPlan Center
College of Design, Construction, and Planning
University of Florida
