Closest facility
1554
10-11-2022 01:12 AM
ahmad_sidani
Hello dears,
I created a road network from my road shapefile and I added 2 Shapefiles to the map:
1st contains 2 features
2nd contains 1232 features
I want to calculate the between the 2 features and the 1232 others so i can get 2464 distances.
I am trying to use closest facility, it works but it only calculates around 100 disntance.
Any suggestions please ?
DanPatterson
MVP Esteemed Contributor
Did you get any errors or warnings?
... sort of retired...
ahmad_sidani
No !! 😞
ahmad_sidani
even when trying to find routes between features of 1 shapefile using "Route" it gives me an error 030212
JaySandhu
You have to first verify that your network dataset has been setup and built correctly. One way you can do that is to use Service Area solver. Place one facility somewhere and set the option to generate Lines and not polygons. Set a large break value and solve. In the output, are all lines being returned? Does it show any disconnected places. The other thing you can do is to use the Explore Network tool to check the connectivity and the impedance values to make sure they are correct.
Explore Network—ArcGIS Pro | Documentation
Jay Sandhu
