A cost in location allocation but not distance or time
1454
09-25-2016 08:14 AM
YADOLANO
Is it possible to make the cost in location allocation network analysis to be something different than time or distance of lines of the network? I have my own attribitue data for lines that I want to make one of the colomn as a cost data not the length or traveling-time consideration.
Any idea? thanks in advance
DanPatterson_Retired
during the network build process you can set the costs to use if the data are in the table used to build the network
A quick tour of the ArcGIS Network Analyst extension—Help | ArcGIS for Desktop
check the section on network properties, when using a wizard construction... there are code equivalents... just look at NA in arcpy help
YADOLANO
Oh that's nice. Thank you.
