3D analyst extract max Z for vector polygon layer
4619
04-26-2015 12:16 AM
DavidOrchard
I'm not sure which tool to use. I've a DTM based on a 50cm grid and a polygon vector layer,
I wish to extract the maximum value from the DTM layer for each polygon and insert into a column (MaxZ) in the vector layer.
Could somebody advise the best tool to use?
DanPatterson_Retired
DavidOrchard
Dan, thank you, just wasn't sure where to start
GabrielUpchurch1
If you have access to 3D Analyst but for some reason not Spatial Analyst, you could use Add Surface Information—Help | ArcGIS for Desktop .
DavidOrchard
Gabriel, thank you, will investigate surface inormation
