MMPK opens in navigator but app crashes when trying to route
2727
17
12-18-2018 01:07 PM
deleted-user--MMnVrog9xw_
I created a MMPK for use in navigator, In Navigator on Android I am able to download the package, open it, scroll around, and search via the locator. However, when I attempt to route to a point; the app instantly crashes with the standard message "Navigator has stopped".
I have tried creating the MMPK several times with different parameters but the result is the same each time. However, it does seem to be an issue with my MMPKs because I was able to successfully route in Navigator on the Navigator tutorial basemap.
The MMPK is being shared through Portal.
Version details:
   Navigator version 2.0.1
   MMPK created using ArcGIS Pro version 2.2.0
Tags (1)
JayJohnson6
New Contributor III
Have you looked at this sort of problem in authentication?
Error: ArcGIS Connection has stopped working
Or, sometimes http and https do not switch over smoothly.
Portal and AGOL authentication in Navigator was a big source of frustration in past versions.
BrentPierce
Jay,
Is there any way you could share the MMPK you are having troubles with?
-Brent
Sure, how should I send it? It's not too large (25MB)
JayJohnson6
New Contributor III
if you are sending to me, only Microsoft OneDrive will work
The file in question is at EQT and/or Equitrans and Rob Lavelle would have to send it to you.  I work at NCDOT now.
JayJohnson6
New Contributor III
I was able to route, in the end the limitation was with AGOL authentication vs. Portal; Derek Law might have it in his notes from a year ago
Jay, just FYI I was able to solve this issue. I updated the post with my solution. Thanks for your help
JayJohnson2
Awesome. I wonder if dissolve would have helped me in early Navigator
problems at BNSF.
I forgot to update this post with the solution that I found:
Running the "Dissolve Network" tool on the network used in the mobile map package fixed the issue.
