Unable to add portal counter
1695
06-05-2020 06:19 AM
VictorTey
Hi, I am trying to setup a portal counter which is in a HA environment.
When setting up the counter, Portal B works however Portal A returned an error. I ran the support.bat to check the logs but found nothing. Would you be able to provide some advise where can I get more information that is causing it to fail?
For example, is it possible to view the request that caused the failure?
I tested bypassing the WA (hit port 7443 directly), password doesn't contain special character.
Account used has administrator privileges.
MattD
by Esri Contributor
It may be beneficial to log a support ticket to explore this issue in more depth. Are you able to resolve Portal B from the ArcGIS Monitor Machine while logged into the user who is running the ArcGIS Monitor Windows service?
MattD
by Esri Contributor
by Anonymous User
Not applicable
Agreed. Not enough info and too difficult to troubleshot via a blog. Please open a case with Esri Support
VictorTey
Hi Matthew Dusch‌ and Michael Reither thank you. We were able to troubleshoot down to the license is not viewable from the rest API. We restarted portal and it is working now.
I was more hoping to be able to see more logs on why something fail rather than just a blackbox error. For example, in this example I had, it would have been helpful if there was somewhere in the logs that states there was a timeout while attempting to read this rest API type of logging. Maybe it is possible but I could not find it in the logs
AlexBell96
Hello, @VictorTey  would you be able to share how you narrowed the above issue down?
I have the exact same error, although a portal restart for this customer is a big ordeal so I want to make sure it is neccessary.
Kind Regards
Alex
