Tune the 'Default Alerts' for ArcGIS Monitor
866
09-24-2021 08:15 AM
AndrewDavis2
Hello,
I am running 10.7 edition of ArcGIS Monitor.  I was able to create a 'Connection' and then connect to my ArcGIS Server (10.6.1).
The default alerts all seemed to work in the test.
I keep getting 'Log-Severe' alerts.  I suspect that the default settings for my Server (the web adapter does not allow remote admin).
Is there a place where I can go to learn how to 'tune' the alerts?
Andy
Tags (3)
ReeseFacendini
Esri Alum
To adjust (add or remove) alerts, go into ArcGIS Monitor Administrator (desktop app) and select the ArcGIS Server connection specific to your server, then at the top of that connection info window, click on the alerts tab.  You can add and remove as many alerts as you'd like, and are not required to keep the default ones at all.  https://enterprise.arcgis.com/en/monitor/10.8/administration/configure-alerts-for-counters.htm
