What are the SQL Server required privileges to capture Geodatabase Metrics? We have registered an Enterprise Geodatabase that is getting DB metrics just not Geodatabase Metrics.
Hi ArcGIS Monitor's help states:
I like to register the geodatabase with the sde administrator credentials so to collect all of the Geodatabase metrics in this link.
Our user has all of these requirements met and is still not getting geodatabase metrics.
A SQL Server-authenticated user account must be used to register the database for monitoring and must be mapped to the database and be granted the View server state permission on the database instance.
Who marks these as Solved?
I believe Derek Law the forum moderator marked my answer as correct.
If you are following all of the above points another potential road block could be a firewall between the ArcGIS Monitor server and your SQL Server machine. Make sure all the prerequisites are met from this link.
Hi @B_Franey,
Yes, it was me who marked it as solved. I thought @StevenBeothy's response was good and since you hadn't responded in over a month, I thought you were good. Apologies for the oversight on my part.
