ArcGIS Monitor 2025 Observer Failure – “Health Check – Portal for ArcGIS” in Portal 11.1 HA Deployment
590
10-16-2025 03:33 AM
Edmar_Tabamo
Summmary:
We are encountering an observer failure in ArcGIS Monitor 2025.0 specifically for the “Health Check – Portal for ArcGIS” observer in a high availability (HA) Portal for ArcGIS 11.1 deployment. All other observers (Inventory, Logs, Metrics) for the Portal component are functioning correctly.
Observations:
1. The Health Check observer fails consistently only in the HA setup.
2. Single-machine (int_dev_portal) Portal deployment do not exhibit this issue.
3. (not sure if this is relevant) but uppon registering the Portal component (int_stg_portal), only one Web Adaptor URL (https://wa2.domain.local/portal) is automatically registered by ArcGIS Monitor, even though the HA setup includes two Web Adaptors.
4. Both Portal machines have agents installed and are visible in ArcGIS Monitor Server.
5. All other components (Portal, Hosting Server, Data Store) are successfully registered.
Please check the attached screenshots for more details.
Action Taken ( No sucess )
1. Restarted the agents's window service
2. Disconnect / connect
3. Run agent discovery from CLI
4. Unregister / Register the portal components
Error Details
  • Observer: Health Check – Portal for ArcGIS
  • Component: int_stg_portal
  • Error Code: E_OBSERVER_FAILURE
  • Message: Run failed
  • Details: timeout of 30000ms exceeded
  • Timestamp: 10/15/2025, 12:15:36 PM
  • Resource: observers:155
  • Severity: Warning
ArcGIS Monitor Server:
  • Version: 2025.0
  • OS: RHEL 8.10 (Ootpa)
  • CPU: 8 cores
  • RAM: 64 GB
  • Network: 10 Gbps
Agent Deployment:
  • Version: 2025.0.1+984
  • OS: Windows Server 2022
  • Machines: 2 Portal nodes with agents installed and reporting
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi @Edmar_Tabamo,
Please open a case with Esri Tech Support. They are the best folks to help investigate further.
Edmar_Tabamo
Hi @DerekLaw
Thank you for your input. We haven't opened a support ticket yet, as we're currently unable to reproduce the issue in another portal HA environment running at version 11.5.
Best regards,
Edmar
