Monitor 2025 Map Image Services in shared instance all reading at 100% when in use
3176
12
06-09-2025 11:17 AM
DavidColey
MVP Frequent Contributor
Hello -
I just finished the 2024.1 to 2025.0 Monitor upgrade.  Now, any of my map image services that use the Shared Instance (Dynamic Mapping Host) show as 100% saturated.  Map Image Services as dedicated types do not.
David
DerekLaw
Esri Esteemed Contributor
Hi @GavinCollins1,
From Esri Tech Support case 03926364, we identified BUG-000157186 for ArcGIS Monitor. There is a workaround and two feature enhancements were created for ArcGIS Monitor.
  • ENH-000168870 - Provide the ability to generate metrics for Shared Instances (DynamicMappingHost) under ArcGIS Server Manager usage Statistics.
  • ENH-000172351 - ArcGIS Monitor does not collect metrics from the DynamicMappingHost service.
Please open a case with Esri Tech Support so we have more information and also prioritize the feature enhancement request.
Hope this helps,
nbrown
I'm having the same issue after completing the upgrade to 2025.0.  My map services with Shared Instance are showing 100% saturation when being used.
DerekLaw
Hi @DavidColey and @nbrown,
Can you please open a case with Esri Tech Support so they can investigate and reproduce the behavior you're seeing?
nbrown
This issue is similar to one that has happened in the past:
Solved: Metrics and Alerts on Shared Instances - Esri Community
ArcGIS Monitor does not like shared instance services that has values for service properties "minInstancesPerNode" and "maxInstancesPerNode" set to 0 even though it should be returning the "number of shared instances per machine" value set in server manager.
I resolved this (for the specific map service having this issue) by setting the minInstancesPerNode value to 1 and maxInstancesPerNode to 2.  After doing so, ArcGIS Monitor then correctly shows the value set for the shared instance pool and the metrics for instance saturation are then correct.
DavidColey
Ok I too can confirm that what @nbrown in his reply and what @NickN in the this post
do work. I went into ServerAdmin and just changed the max maxInstancesPerNode value to 1 and left the minInstancesPerNode at 0 and am now getting small percentage sat values (like 0.45, 0.56, etc) for these services in the shared instance:
Configured State
Started
Instance Type
Shared
Instance Limits
0 min - 16 max
One of us should still probably report it to support so they can be aware and get a fix, since I still don't know if the Instances node counts are going to revert back to 0,0 when the server restarts or when the ArcGIS Sever exe service restarts....
DavidColey
Yeah once a shared service restarts it will revert back to it's 0.0 setting for min and max InstancePerNode counts and then the Instance Saturation again graphs that service saturation value as 100%
DavidColey
@DerekLaw Esri Case #03926364
David
DavidColey
Ok, I did a screen share with support on this on 06/17, demonstrated the issue by showing the workaround and now we'll see.
GavinCollins1
@DavidColey @DerekLaw was this issue qualifed as a bug? I am also experiencing the same issue in an ArcGIS Monitor 2025.0 deployment.
DerekLaw
Hi @GavinCollins1,
Hope this helps,
