Monitor 2024.1- unable to register Portal server
3242
13
10-21-2024 09:01 AM
EricJohnson-HDR
When trying to register the Portal machine, I get a "Cannot read properties of undefined (reading 'version')" error. Nothing yet on the Google machine and not sure where to go. Same account used for all other machine in the environment. Have done the WMI steps and added user to Performance Monitor users....
Anyone have thoughts? Thanks
CodyPatterson
MVP Regular Contributor
Not really sure why it didn't occur to me, but this is also the same error I got when my username and password was incorrect.
I had to use the portaladmin account that was created when it was first deployed.
Cody
CodyPatterson
Hey @EricJohnson-HDR
Would it be possible to test the firewall by temporarily disabling it? Other than that, you could add the ports for the Monitor manually through the advanced firewall rules.
Cody
EricJohnson-HDR
It shouldn't be a port issue unless its using something other than 30443 to talk back to the Monitor host.  Thanks for the suggestion though.
CodyPatterson
Should just be 30443, something else to test, what is the version of Monitor and Enterprise you are using? Inside of Portal Admin, is version filled in?
Cody
EricJohnson-HDR
Cody, Monitor 2024.1 and 11.3 Enterprise.
Thanks
CodyPatterson
Gotcha, are you able to see the version information I have in the last screenshot?
Cody
EricJohnson-HDR
Yes, see below...
CodyPatterson
My final idea before I say that ESRI support would be best would be to check the file in this location:
C:\Program Files\ArcGIS\Portal\framework\etc -> config-store-connection.json
If you open up the config-store-connection.json, is the version information present?
Should show something like this:
Cody
Craig_Lunde
I got that error too and for me it was wrong username/password.
CodyPatterson
Cody
