Issue after Upgrading to 2024.1 : Unable to Register DataStore
789
02-04-2025 07:22 AM
IrisHadarStltd
I upgraded from version 2024.0.2 to 2024.1, and encountered the following error when trying to register the DataStore:
'no pg_hba.conf entry for host "127.0.0.1", user "siteadmin", database "db_2u72f", SSL on'
Could you please advise on the steps I need to take to resolve this and register the DataStore correctly?
DerekLaw
Esri Esteemed Contributor
Hi @IrisHadarStltd,
FYI,
I am linking this thread to another similar topic thread,
2024.1 ArcGIS Datastore Invalid Version: 11.3.0.51575
Apologies for this issue. The Monitor team is working on a patch to resolve this. I will post an update to the other thread when we have news to share.
Hope this helps,
DerekLaw
All,
UPDATE: the ArcGIS Monitor 2024.1.1 patch that addresses this issue is scheduled for release on March 20.
Thanks for your continued patience,
DerekLaw
Hi @IrisHadarStltd,
The error message,
may actually be related to a permissions access issue for ArcGIS Data Store.
Can you please try running the ArcGIS Data Store allowconnection command - to enable AM Agent to connect to the data store?
ArcGIS Data Store utility commands
(see allowconnection)
Then, please follow the Register ArcGIS Data Store help and run the listadminusers command.
Apologies for the confusion as your issue is might not be related to this thread, 2024.1 ArcGIS Datastore Invalid Version: 11.3.0.51575.
Hope this helps,
