Creating Customer Notifications in ArcGIS Monitor 2024.1
681
12
a month ago
HannahSturm
Trying to figure out how to create better email notifications in ArcGIS Monitor 2024.1. Saw the "What's New in ArcGIS Monitor 2024.1" blog that showed that it is possible to make the notifications in email understandable. Does anyone know how this is achieved? I haven't been able to find any documentation from ESRI on how they created this.
DerekLaw
Esri Esteemed Contributor
Hi @HannahSturm,
The contents of email notifications from ArcGIS Monitor are not currently customizable. This information will be populated by Monitor. Only the email subject line is customizable at this time.
Hope this helps,
HannahSturm
That's unfortunate, that's not what that blog post is showing or saying though. Very misleading. Is this functionality coming  though to get it show like the screenshot?
DerekLaw
Hi @HannahSturm,
I'm not clear on what you're saying. The image you attached from the What’s New in ArcGIS Monitor 2024.1 blog is an actual screenshot of an email notification from Monitor. This was taken from one of our test machines.
Hope this helps,
HannahSturm
Hi Derek,
Attached is what I'm currently being sent in email via the notifications from Monitor. Are you saying that we are not able to customize my screenshot to look like the screenshot that came from the test machine where it has the layer name, state, status, etc?
DerekLaw
Hi @HannahSturm,
In your second screenshot, it looks like you've configured a notification on a component's metrics. So what you're seeing is expected. I suspect you need to configure your notification to trigger based on an alert becoming active, not on a component metric.
What do you want to be notified on? Then can you please share a screenshot of how you've configured the notification?
ChazArmijo
i'm trying to accomplish the same as @HannahSturm. i created a custom notification based on a specific alert and i'm still getting very little information in the email
DerekLaw
Hi @ChazArmijo,
The notification configuration appears correct based on what I can see in the screenshot. What release of ArcGIS Monitor are you using?
ChazArmijo
DerekLaw
Hi @ChazArmijo,
2024.0.0
You'll need to upgrade your ArcGIS Monitor instance to 2024.1 or higher. The notification email content enhancements (mentioned in the original post of this thread) were added in the Monitor 2024.1 release.
Hope this helps,
