Cannot create Check service observer in ArcGIS Monitor
115
a week ago
Vincent828
Hi, we would like to monitor a custom application URL by ArcGIS Monitor Check - Service observer. However, we cannot enable the optional metric as follows, according to the documentation (Register ArcGIS Server—ArcGIS Monitor | Documentation). Just want to clarify if it appropriate to use Check - Service observer to monitor custom application. Also, is there any trick to create Check-Service observer?
StevenBeothy
The Check Service Observer introduced at version 2024.1 currently only works with registered GIS Services.
  • Check - Service is an optional, user-configured observer that sends a request to an ArcGIS Server service and uses a regular expression pattern to validate its JSON response.
StevenBeothy
DerekLaw
Esri Esteemed Contributor
Hi @Vincent828,
@StevenBeothy already answered this question. The Check Service observer only works with registered service components in Monitor.
This is not currently possible in ArcGIS Monitor. Please submit a feature enhancement request in the ArcGIS Monitor Ideas forum.
> ... is there any trick to create Check-Service observer?
To enable and apply the Check-Service observer, under the Monitoring page > select a service component > Observers subtab. Click the Add observer button to display the Add Observer dialog. For Observer Type, select Check – Service.
Hope this helps,
