ArcSOC widget(s)
1087
04-15-2024 08:23 AM
Mike_Tulis
I am looking for help with configuring an ArcGIS Monitor widget(s) that would:
1.   count ArcGIS Server ArcSOCs in use
2.   display sum of min and max ArcSOCs allocated to all services
3.   show linear chart of top 10 services / ArcSOCs based on memory use.
We have a wide range of min and max instances across all services on the Server. I am hoping to configure a widget that would help me identify correlation between high number of ArcSOCs in use and hardware/server performance. Many of them area seasonal (used May-October only) and/or used seldom. These widgets would help with hardware sizing or moving services to other machine.
GeoJosh
@Mike_Tulis, here are a few more ideas that I think answer your questions:
ArcSOC Process Instances, per machine
Data Expression
Chart Configuration
NOTE: Edited at 3:52 on 4/18. The previous iteration suggested "Statistic Type: Sum" but "Maximum" is more appropriate for this use case, as pictured below:
Min/Max ArcSOC Instances
Data Expression
Chart Configuration
Change "Statistic Field" to "Instances Min" for minimum number of ArcSOCs.
Top Services by Memory Usage
Data Expression
Chart Configuration
Josh
AndrewSakowicz
perhaps you can use Solved: Analysis from ESRI Developer Summit 2024 - Esri CommunityAndrewSakowicz_1-1713196911695.png
if you want to see memory usage per service, duplicate the above tile and use the following expression
for total number of arcsocs:
Also, the following blogs might be helpful: https://community.esri.com/t5/arcgis-monitor-blog/arcgis-monitor-analysis-elements-for-enterprise/ba...
https://community.esri.com/t5/arcgis-monitor-blog/5-useful-arcgis-server-analysis-elements-in-arcgis...
GeoJosh
Data Expression
Chart Configuration
Data Expression
Chart Configuration
Data Expression
Chart Configuration
Josh
MariuszZ_EPL
Hi
For diagnostic purposes, I created a PowerShell script to monitor ArcGIS Server's ArcSOC.exe processes over time. It captures memory usage data at regular intervals and logs the results to a CSV-style text file for further analysis.
Why is the number of arcsoc.exe instances different in the PowerShell script than what ArcGIS Monitor shows?
# Configuration
$logFile = "C:\esri\ArcSOC_Monitoring.log" # Path to the log file
$repeatCount = 30 # Number of measurement repetitions
$intervalMinutes = 1 # Time interval between measurements in minutes
# Add header to the log (if the file does not exist)
if (-not (Test-Path $logFile)) {
"Timestamp,Count,RAM_WorkingSet(GB),RAM_PrivateMemorySize(GB)" | Out-File -Append $logFile
# Measurement loop
for ($i = 1; $i -le $repeatCount; $i++) {
# Retrieve ArcSOC.exe processes
$processes = Get-Process -Name ArcSOC -ErrorAction SilentlyContinue
# Count the number of instances
$instanceCount = $processes.Count
# Sum memory: WorkingSet
$totalMemoryWorkingSet = ($processes | Measure-Object -Property WorkingSet -Sum).Sum
$totalMemoryWorkingSetGB = if ($totalMemoryWorkingSet) { [math]::Round($totalMemoryWorkingSet / 1GB, 2) } else { 0 }
# Sum memory: PrivateMemorySize
$totalMemoryPrivate = ($processes | Measure-Object -Property PrivateMemorySize -Sum).Sum
$totalMemoryPrivateGB = if ($totalMemoryPrivate) { [math]::Round($totalMemoryPrivate / 1GB, 2) } else { 0 }
# Get timestamp
$timestamp = (Get-Date).ToString("yyyy-MM-dd HH:mm:ss")
# Write to log
"$timestamp,$instanceCount,$totalMemoryWorkingSetGB,$totalMemoryPrivateGB" | Out-File -Append $logFile
# Display results in console
Write-Output "[$timestamp] Instance count: $instanceCount | WorkingSet: $totalMemoryWorkingSetGB GB | PrivateMemory: $totalMemoryPrivateGB GB"
# Sleep interval (skipped after the last measurement)
if ($i -lt $repeatCount) {
Start-Sleep -Seconds ($intervalMinutes * 60)
Write-Output "Monitoring completed. Results saved in file: $logFile"
