ArcGIS Monitor vs SOEs
347
3 weeks ago
WalterSimonazzi_VicPol
We have a map service with an SOE (Server Object Extension) enabled. This service is exclusively accessed through the SOE and is one of the most frequently used services in our ArcGIS Enterprise environment.
However, ArcGIS Monitor 2024.0 does not appear to capture any activity for this service, as if it is not being used. Is there a way to configure Monitor to track this service and alert us when it is not functioning as expected?
DerekLaw
Esri Esteemed Contributor
Hi @WalterSimonazzi_VicPol,
This is difficult to assess, as it will depend on what the SOE does. A guess is that it does something which prevents data being properly written to the ArcGIS Server usage reports - which is partly where ArcGIS Monitor gets some metrics.
Please contact Esri Tech Support and open a case so they can help investigate further.
Hope this helps,
