ArcGIS Monitor does not register the Portal component in HA
1727
7
02-15-2023 02:32 AM
Oiligriv
HI
I'm setting up an ArcGIS Monitor 2023 on an ArcGIS Enterprise installation in HA.
all components have been successfully registered except Portal for ArcGIS.
when I register, the Monitor only warns me of a problem without specifying anything else.
I also opened a Browser with the user running the ArcGIS Monitor service to check if it successfully reached the Portal correctly.
I tried to register both through WebAdaptor and through port 7443 but without success.
i managed to catch the error via the Browser with specified token error.
below is a screen
Thank you
Virgilio
GeoJosh
Hi Virgilio,
Thank you for taking the time to report this. This error is a known issue and a fix will be included in an upcoming ArcGIS Monitor patch.
Josh
BillFox
MVP Notable Contributor
What's the bug number for this one?
TariqAlOtaibi
Hi Josh,
no workaround available ? until we get the patch
Thank you.
Tariq
TimSwalin
Any updates on when the patch will be available?  I am also experiencing this issue.
DerekLaw
Esri Esteemed Contributor
Hi @TariqAlOtaibi and @TimSwalin,
The ArcGIS Monitor 2023.1 minor release (which will contain the bug fix) is scheduled for release at the end of April/early May timeframe.
Hope this helps,
Jeremy_Hayden
Hi Derek
Will that Patch be available via My Esri? I notice that Monitor doesn't have the usual patch/update application included with it.
DerekLaw
Hi @Jeremy_Hayden,
ArcGIS Monitor 2023.1 contains the fix, see the release notes. We won't be releasing specific patches, just software releases. FYI - ArcGIS Monitor 2023.1 release blog.
You can upgrade to ArcGIS Monitor 2023.1 in place.
Hope this helps,
