ArcGIS Monitor 2023.2 - ArcGIS Server services status and its metrics status shown as 'Unknown' instead of Nominal (alerting is ON)
1780
11
08-02-2024 01:28 AM
NaveenK
Hello Guys,
ArcGIS Server services status and its metrics status showing as 'Unknown' instead of Nominal despite alerting being set on certain metrics.
Toggling the alerting OFF/ON  puts the status back to 'Nominal'.  This may be a workaround but can't do this for all the services (and its metrics).
Naveen
NaveenK
Ended up unregister and registering it back again. It looks OK now. I need to monitor to see if it returns back,
DerekLaw
Esri Esteemed Contributor
Hi @NaveenK,
As I mentioned earlier in this thread, I encourage you to upgrade your ArcGIS Monitor instance to a more current release so you'll have the benefit of all the fixes that were addressed.
Hope this helps,
