2024.1 keeps clearing filter rule
972
8
02-03-2025 08:54 AM
Joshua-Young
Honored Contributor
After upgrading to 2024.1, widgets using "contains" or "does not contain" in filters keeps having that rule cleared after clicking "Done". I have tried filtering on different fields and using "is" or "is not" and the common denominator that clears out the rules is using "contains" or "does not contain". Many of my widgets are now broken.
"Not all those who wander are lost" ~ Tolkien
DerekLaw
Esri Esteemed Contributor
All,
UPDATE: the ArcGIS Monitor 2024.1.1 patch that addresses this issue is scheduled for release on March 20.
Thanks for your continued patience,
JakeNeedle
I am having the same issue since the upgrade to 2024.1. Does anybody have a work around?
DavidColey
MVP Frequent Contributor
Yeah same here, no workaround yet.
DavidColey
Yeah its really bad too because we lost Instance Saturation % and that's like one of the primary measures I really need, I'm sure others do to.  But just @Joshua-Young says, anytime I try to recreate an Instance Saturation analysis data view and graph, it just clears the filter.
JakeNeedle
@DerekLaw is the Monitor team looking into this issue? Thanks
DerekLaw
Hi @JakeNeedle,
Yes, we are looking into the issue.
All,
Can you please contact Esri Tech Support and open a case, so we can collect more information as we investigate this issue?
DerekLaw
All,
Apologies for this issue. The Monitor team is working on a patch to resolve this. I will post an update when we have news to share. Thanks for your patience.
Hope this helps,
DerekLaw
All,
Joshua-Young
Honored Contributor
To anyone following this, ArcGIS Monitor 2024.1.1 is up on My Esri now and it fixed this issue for my organization.
