New columns for ArcGIS Montior own logs
476
07-27-2023 02:13 AM
bernhard
New Contributor II
it would be helpful for failure investigation if the ArcGIS Monitor own logs overview would allow additional columns for
- component name
- observers name
- message details
These columns would increase the chance to find the correct log entry in the mass of logs the software produces...
Thanks.
3 Comments
JamesBratton
The ArcGIS Monitor admin logs show failures on multiple resources, but they do not tell you what resource is affected.  In order to find the resource, you are required to query the database using the observer ID in the log.  I would like to suggest that the log entry show the resource name so that we don't have to look up the affected resource in the database.  The ArcGIS Monitor database has an observer table that has a foreign key to the components table.  If you look in the component table, you will find the component name and know what resource is creating log entries in ArcGIS Monitor.
GeoJen
by Esri Contributor
GeoJosh
