Admin Utility for ArcGIS Monitor - DEPRECATED
3135
8
06-01-2023 04:15 PM
AndrewSakowicz
Admin Utility for ArcGIS Monitor is a python command line utility to assist administrators with:
  1. Deployment scripting: setup, users, labels, components, collections, analysis
  2. Batch updates: intervals, alerts
Downloadhttps://prof-services.maps.arcgis.com/home/item.html?id=129f2dbfde634f12bfae6f41121c9ff1
Usage
To run using provided executable for windows
dist\AdminUtility.exe -f sampleConfig.json -o xxx
-o values: setup, users, labels, components, collections, analysis, intervals, alerts
To run as python script
pip install -r requirements.txt
AdminUtility.py -f sampleConfig.json -o xxx
Note, this utility is not an ArcGIS Monitor product supported feature or a supported Esri product.
8 Comments
MaurusErni1
Occasional Explorer
Hi @AndrewSakowicz
We're using ArcGIS Monitor 2023.3.1 and would like to use the Admin Tools to import/export configuration and settings from stage to stage.
The REST API OpenAPI documentation URL you mentioned above is invalid on our installation: https://xxxx:30443/arcgis/apidoc
Calling this URL with ArcGIS Monitor 2023.3.1 returns a 404 (not found). Any hint how/where to reach the REST API OpenAPI?
Regards
Maurus Erni
AndrewSakowicz
Thank you for pointing this out. I corrected the article.
Note, we are making several changes and are working on documenting and offering fully support Rest API in later releases.  We'll announce when it's ready.
GeorgePan
Hi Andrew,
I hope you had a great Independence Day and enough rest.
After testing the Admin Utility for ArcGIS Monitor, I feel it is so powerful and love it very much. It will be a powerful GIS automation tool to help us to publish ArcGIS monitor settings from Dev to Test, UAT, Staging, and Production environments.
Can I bother you answering some questions to help us get more details?
Here are testing results and questions:
Test Results
Test Report of Admin Utility for ArcGIS Monitor
OS: Windows Server 2019
Version: ArcGIS Monitor 2023.3.1
Date: July 5, 2024
CMD/Python: Both
xyz Values
Test Results
Comments
Setup
No need for us
No testing has been applied
Users
Good - see the new users were added successfully
Fast and good
Labels
Good - see the new labels were added successfully
Fast and good
Components
Good - see the SQL Server was registered successfully
Fast and good
Collections
Good but how to set complicated union of lables
Need to add "encrypt": "false" for SQL Server accounts. Windows accounts do not need it.
Analysis
Error
The sample only has "file" parameter, no name, desc, and configuration. See error message Err-Ana-01
Intervals
Error
See the error message Err-Int-01
Alerts
Works well.
Slow
Questions
  1. Can we have sample in the configure file to modify / remove a user?
I saw the arcgis-monitor-admin-utility-20231229.1\Modules\AGM_API\Admin\users.py only has:
def add_user(self, payload)
Do you have API document for end point URLS and syntax?  Then we can add Python script for updating and deleting.
Such as:
route = "/arcgis/admin/security/users/delete/id"
response = requests.request("DELETE", self.url + route, json=payload, headers=headers,
        verify=False) "
  1. How to set a label’s description and color?
The current code only handles the label names. Should we change the following 2 things, to make it work?
  • The configuration from "labels":["xy"] to "labels": [{"name” : “xy", “description”: ”Desc”,"color":””}]
  • The payload = {"name":name} to {"name":name, “description”, desc, “color”: “#e5eb73”},
  1. Can you provide a sample configuration for how to set expression or labels for the following complicated case:
We have 2 labels “Dev” and “EFFMaps”, we can label a collection using the following Expression to make it have both properties, without creating a new label “Dev EFFMaps”. How to implement this in the Admin Utility?
  1. For the -o analysis, can you provide a sample to set name, description, and Data Expression? I got the error message when use the setting. Any solutions?
"analysis":[
                {"name": "CodeSample", "description": "Code Sample Description","file":"C:\\temp\\ArcGISMonitor\\AnalysisSamples\\prodAnalysis.json"}],
Err-Ana-01:
7/05/2024 11:04:01 AM INFO: version:20231229.1
07/05/2024 11:04:01 AM INFO: Start
07/05/2024 11:04:01 AM INFO: Arguments: ConfigTry.json, analysis
07/05/2024 11:04:01 AM INFO: https://xyz.cc.uuuu:30443
07/05/2024 11:04:03 AM INFO: Get token success: True
07/05/2024 11:04:05 AM ERROR: Error adding analysisC:\temp\ArcGISMonitor\AnalysisSamples\prodAnalysis.json :{"success":false,"error":{"code":"E_VALIDATION_FAILED","status":400,"message":"Input validation failed for operation","details":["name is required."]}}
07/05/2024 11:04:05 AM INFO: End
"intervals":[
        {"minutes":65, "component_names":["ServerD01A","ServerD01B"], "component_types":["host_windows_strategy"]}],
"analysis":[
  1. For the -o intervals, I got the following error, any solutions?
Setting:
"intervals":[
Err-Int-01:
'Components_build' object has no attribute 'config'
  File "AdminUtility.py", line 10, in main
  File "Modules\Builder\builder.py", line 83, in __init__
  File "Modules\Builder\components_build.py", line 124, in update_intervals
AttributeError: 'Components_build' object has no attribute 'config'
None
  1. Can you provide a sample to unregister components in the configuration file?
Thanks so much for your great work!
George
GeorgePan
Configuration json file is:
    "server":{
        "username": "SiteAdmin",
        "password": "SiteAdminPassword"
    "password_encoding": false,
    "setup":{
        "initial_admin":{
            "username": "admin",
            "password": "xyz",
            "email": "xyz",
            "name_first": "Primary",
            "name_last": "Administrator"} ,
        "pg_database":{
            "host": "xyz",
            "port": 5432,
            "database":"xyz",
            "username": "xy",
            "password": "xyz"},
        "register_monitoring": {
            "strategy_r_id":"boundary_physical_strategy",
            "connection":null}
    "users":[
            "username": "agm1_viewer",
            "password": "Password",
            "name_first": "agm1_viewer_first",
            "name_last": "agm1_viewer_last",
            "email": "agm1_viewer@xyz.com",
            "role": "viewer"
            "username": "agm1_admin",
            "name_first": "agm1_admin_first",
            "name_last": "agm1_admin_last",
            "email": "agm1_admin@xyz.com",
            "role": "admin"
    "labels":["xy", "xyz"],
    "register_localhost":
            "name": null,
            "strategy_r_id":"host_windows_strategy",
            "connection": {
                "address": null,
                "os_credentials":true
            "interval":null,
            "agent_name":"xyzx",
            "labels":["xyz"]
    "components":[
            "name": "localPostgreSQL",
            "strategy_r_id":"database_pg_strategy",
            "description": "localPostgreSQL",
            "connection":{
                "address": "localhost:5432",
                "database":"ArcGISMonitorAppDataBase",
                "encrypt" : "false",
                "ssl":"false",
                "username":"arcgismonitorPDBAdmin",
                "password":"Password"
            "interval":60,
            "agent_name":"arcgismon01.cc.uuuu",
            "labels":["DB", "PDB","TST"]
    "unregister":["server1.cc.uuuu", "server2.cc.uuuu"],
    "collections":[
            "name":"TestByCode",
            "description":"Test by code",
            "label_name":"TST"
    "intervals":[
        {"minutes":65, "component_names":["Server01","Server1B"], "component_types":["host_windows_strategy"]}],
    "analysis":[
            {"name":"CodeSample", "description": "Code Sample Description","file":"C:\\temp\\ArcGISMonitor\\AnalysisSamples\\prodAnalysis.json"}
    "alerts":[
            "name": "CPU Utilized",
            "is_alerting_enabled": true,
            "operator": ">",
            "warning_threshold": 60,
            "critical_threshold": 85,
            "aggregation": "avg",
            "samples": 5,
            "collections":["Dev01"]
            "name": "Memory Utilized",
            "operator": ">",
            "samples": 5,
            "collections":["Dev02"]
AndrewSakowicz
A couple of comments:
  1. Some API calls and payloads, including registering components, will change in the next release.
  2. At this point, I don't have updates for this admin utility or enhancements.
  3. Instead, we are planning on finalizing and documenting API, including Python API in the next releases.
  4. So, my recommendation is that you evaluate your enhancement investment.  Instead of enhancing it, perhaps use it as is and for outstanding features configure them using UI, e.g. Collections, labels.
  5. But if you still would like to enhance it, the "reverse engineering" using web dev tools might be the easiest way.  For example, to delete users AndrewSakowicz_0-1720300507140.pngAndrewSakowicz_1-1720300555175.png
GeorgePan
Thanks so much for the quick feedback 🙂
Yes, reverse engineering is very helpful, and it has helped in finding some answers.
Will the API documents come with ArcGIS Monitor 2024?
Another thing is I heard we still must enable the ArcGIS Server Primary admin account to register a GIS Server component in the new ArcGIS Server version 2024, like we did in version 2023.3, which is a risk on the security side. Is that true?
Best regards,
George
AndrewSakowicz
API documents will not be available in this upcoming 2024.0, but is planned for later this year.  We'll share details later.
I would not interpret disabling PSA recommendation because it is a security risk, see Disable the primary site administrator account—ArcGIS Server | Documentation for ArcGIS Enterprise.  It is not a security risk per se. This recommendation reflects more of "least privilege access" principle.  If you don't need two ways of admin access, disable it.  But if you need to script admin functions or effective monitoring, need PSA.
GeorgePan
Thanks so much for the quick feedback and sorry for costing your weekend's time Andrew, 🙏🍺
We are looking forward to seeing the version 2024.0 and appreciate your sharing the changing on APIs and documents in the future.
Yahoo!
George
Contributors
