How important is BIS metadata schema? Can it change?
157
11-21-2025 10:47 AM
ARyanWADNR
Hi All!
I am rebuilding my BIS using the ArcPro toolbox, and have run into an issue with the metadata schema template. Namely, If I select the BAG schema it wont let me add any other type of data. Is this a known limitation?
If it is expected, is there a way to modify the current metadata schema so that I can add other raster types?
Thanks All!
