Create ENC in ArcMap
7974
6
06-16-2023 07:57 PM
NguyenBichHue
Hi Technical Support Team,
I have some issues when working with ArcGIS for Maritime in ArcMap as attached pictures.
1. I have problem with NIS scale band although I already configure as the picture 1, and picture 2
2. I try to create New Nautical product but the tools are not active as picture 3.
Please help me.
Thank you so much
2 Solutions
pocalipse
Hi
We had the exact same problem in ArcGIS 10.8 but everything was working in 10.7! Unfortunately we didn't find any solution.
NguyenBichHue
I found that should work with Enterprise Geodatabase in Arcmap 10.7
pocalipse
Hi
NguyenBichHue
Hi
Thank you so much for support. I already installed version ArcMap 10.7 and I can work with the NIS Scale band.
However, I still have problem with New Nautical Product wizard. The tools in this wizard are not available active , although I already set Nautical properties as the attached pictures.
Please help me!
Many thanks
pocalipse
... have you set the NIS Owner Workspace ?
NguyenBichHue
I do as your guide to set the NIS Owner workspace and also in Series Properties, but I still can not select AOI in New Nautical Product. Please help me.
Thanks you so much
NguyenBichHue
I would like to understand that this is a reason that I cannot select the AOI in the New Nautical Product Wizard? as the attached picture, in item Areas Of Intereset: No Custom Object.
Please help me!
Thank you so much
NguyenBichHue
