If you've ever had to show the density of point features on a map, you may already be familiar with the concept of a heat map, which allows you to generalize the display of points according to their density. A heat map provides an excellent tool for discovering patterns in your data. In addition to looking at density of point location, you can also provide a field in your dataset with which to weight the density. This allows you to look at the density of things like sales (dollars, for example) instead of just the density of customers over an area.
Heat maps are displayed with a color ramp that usually shows dense areas with a darker color (red, for example) and sparse areas with a light color (such as yellow). You may have used a heat map renderer to display your point data in the ArcGIS Online map viewer or ArcGIS Pro. The heat map below shows the density of earthquakes weighted with a field that contains the magnitude.
"Sounds great". You might be saying. "I'm excited to try it in my ArcGIS Runtime for .NET app"!
"Um, yeah. About that." I would say, sheepishly looking at my shoes.
While there is support in ArcGIS Runtime for reading things like a heat map renderer from a web map, there's no API exposed (as of v100.2.1) that allows you to construct one and apply it to a point layer without crafting the raw JSON definition. Fortunately, with a little effort, there's a way to make it much easier to work with.
In a previous blog, I described how to create a serializable class to define labeling properties to apply to a layer. I'll describe the same technique here to define a heat map renderer class that can be serialized to JSON and applied to your point layer. If you don't really care about the details and just want to start using it, you can download the completed class and sample project and give it a try.
using Newtonsoft.Json;
using System;
using System.Collections.Generic;
using System.Windows.Media;public long BlurRadius { get; set; }Based on the specification, here are the properties (and corresponding data type) needed for the heat map renderer class:public string Type { get; set; } = "heatmap";[JsonProperty("blurRadius")]
public long BlurRadius { get; set; }public partial class ColorStop
[JsonProperty("ratio")]
public double Ratio { get; set; }
[JsonProperty("color")]
public int[] Color { get; set; }
}public ColorStop(double ratio, Color color)
Ratio = ratio;
Color = new int[] { color.R, color.G, color.B, color.A };
}[JsonProperty("colorStops")]
public List<ColorStop> ColorStops { get; set; } = new List<ColorStop>();public void AddColorStop(double ratio, Color color)
if (ratio > 1.0 || ratio < 0.0) { throw new Exception("Argument 'ratio' must be a value between 0 and 1."); };
ColorStop stop = new ColorStop(ratio, color);
ColorStops.Add(stop);
public void ClearColorStops()
ColorStops.Clear();
}public string ToJson()
return JsonConvert.SerializeObject(this);
}// Create a new HeatMapRenderer with info provided by the user.
HeatMapRenderer heatMapRendererInfo = new HeatMapRenderer
BlurRadius = blurRadius,
MinPixelIntensity = minIntensity,
MaxPixelIntensity = maxIntensity
// Use a selected field to weight the point density if the user chooses to do so.
if (UseFieldCheckBox.IsChecked == true)
heatMapRendererInfo.Field = (FieldComboBox.SelectedValue as Field).Name;
// Add the chosen color stops (plus transparent for empty areas).
heatMapRendererInfo.AddColorStop(0.0, Colors.Transparent);
heatMapRendererInfo.AddColorStop(0.10, (Color)StartColorComboBox.SelectedValue);
heatMapRendererInfo.AddColorStop(1.0, (Color)EndColorComboBox.SelectedValue);
// Get the JSON representation of the renderer class.
string heatMapJson = heatMapRendererInfo.ToJson();
// Use the static Renderer.FromJson method to create a new renderer from the JSON string.
var heatMapRenderer = Renderer.FromJson(heatMapJson);
// Apply the renderer to a point layer in the map.
_quakesLayer.Renderer = heatMapRenderer;I'd agree with you if you think this is a lot of code to write to implement a heat map renderer. But remember, this class can be used in all your ArcGIS Runtime for .NET apps when you want to apply heat map rendering.
Apologies if you were unable to successfully follow the steps above. Fortunately, the attached project contains the HeatMapRenderer class, as well as a WPF app for testing the heat map renderer.
