Announcement to developers using cocoapods with ArcGIS Runtime SDK for iOS
1810
12-15-2020 12:49 PM
DiveshGoyal
If you use cocoapods to integrate ArcGIS Runtime SDK for iOS with your Xcode projects, some important changes are coming your way.
In December 2020, the pods for version 100.6.0, 100.7.0, and 100.8.0 will become unavailable. This is because the downloads for these versions are hosted on JFrog's Bintray service, which is being deprecated by the vendor and will soon be shut down. This has also impacted our Gradle and Maven integrations for ArcGIS Runtime SDKs for Java and Android
Unfortunately, we cannot absorb the impact of this interruption because cocoapods does not permit modification to pods that have already been released. So, we have released new 100.6.1, 100.7.1, and 100.8.1 pods that are functionally equivalent to their predecessor. In fact, they use the same ArcGIS Runtime download as before, simply hosted in a new location. Please upgrade your podfile to refer to these versions instead.
These changes do not apply to you if you are using a different version from cocoapods, or if you manually install and integrate ArcGIS Runtime SDK for iOS using the installer package available on developers.arcgis.com
