in standalone run from Unreal editor or package arcgis map sdk not load anything
694
09-05-2024 01:14 AM
SurikatosDesign
Hello, having issue with standalone/package - arcgis plugin not loading anything in standalone(if running from editor) or package, it only load map in editor(same viewport or pie), what I am missing? I am using apikey. Using arcgis SDK 1.6 and unreal engine 5.3.2 in windows 11 64bit. Package is crashing on run.
Jade
by Esri Contributor
In unreal editor, if you run in standalone or "launch game", the map data doesn't load, this is a known issue on our list. We will raise the priority of this issue with this post. However, if you package the game (platform-->windows--->package project), you should be able to see the map data.
