Hi All,
I've been trying to compile the samples project without success.
I tried build, rebuild, clean+build and I always get the same output log:
Build started at 00:40...
1>------ Build started: Project: sample_project, Configuration: Development_Editor x64 ------
1>Build started 12/03/2024 00:40:59.
1>Target Build:
1> Using bundled DotNet SDK version: 6.0.302
1> Running UnrealBuildTool: dotnet "..\..\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll" sample_projectEditor Win64 Development -Project="Z:\TEMP\new\sample_project.uproject" -WaitMutex -FromMsBuild
1> Log file: C:\Users\info\AppData\Local\UnrealBuildTool\Log.txt
1> Building sample_projectEditor...
1> Using Visual Studio 2022 14.36.32545 toolchain (C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.36.32532) and Windows 10.0.22621.0 SDK (C:\Program Files (x86)\Windows Kits\10).
1> [Upgrade]
1> [Upgrade] Using backward-compatible build settings. The latest version of UE sets the following values by default, which may require code changes:
1> [Upgrade] bLegacyParentIncludePaths = false => Omits module parent folders from include paths to reduce compiler command line length. (Previously: true).
1> [Upgrade] CppStandard = CppStandardVersion.Default => Updates C++ Standard to C++20 (Previously: CppStandardVersion.Cpp17).
1> [Upgrade] WindowsPlatform.bStrictConformanceMode = true => Updates MSVC strict conformance mode to true (Previously: false).
1> [Upgrade] Suppress this message by setting 'DefaultBuildSettings = BuildSettingsVersion.V4;' in sample_projectEditor.Target.cs, and explicitly overriding settings that differ from the new defaults.
1> [Upgrade]
1> [Upgrade]
1> [Upgrade] Using backward-compatible include order. The latest version of UE has changed the order of includes, which may require code changes. The current setting is:
1> [Upgrade] IncludeOrderVersion = EngineIncludeOrderVersion.Unreal5_0
1> [Upgrade] Suppress this message by setting 'IncludeOrderVersion = EngineIncludeOrderVersion.Latest;' in sample_projectEditor.Target.cs.
1> [Upgrade] Alternatively you can set this to 'EngineIncludeOrderVersion.Latest' to always use the latest include order. This will potentially cause compile errors when integrating new versions of the engine.
1> [Upgrade]
1> Determining max actions to execute in parallel (14 physical cores, 20 logical cores)
1> Executing up to 14 processes, one per physical core
1> ------ Building 4 action(s) started ------
1> [1/4] Compile [x64] Module.sample_project.cpp
1> Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(70): error C4459: declaration of 'TraceLength' hides global declaration
1> Z:\TEMP\new\Source\sample_project\Measure\Measure.cpp(20): note: see declaration of 'TraceLength'
1> Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(146): error C4459: declaration of 'TraceLength' hides global declaration
1> Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(257): error C4459: declaration of 'TraceLength' hides global declaration
1> Total time in Parallel executor: 4.24 seconds
1> Total execution time: 4.93 seconds
1> C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command ""C:\Program Files\Epic Games\UE_5.3\Engine\Build\BatchFiles\Build.bat" sample_projectEditor Win64 Development -Project="Z:\TEMP\new\sample_project.uproject" -WaitMutex -FromMsBuild" exited with code 6.
1>Done building target "Build" in project "sample_project.vcxproj" -- FAILED.
1>
1>Done building project "sample_project.vcxproj" -- FAILED.
1>
1>Build FAILED.
1>
1>Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(70): error C4459: declaration of 'TraceLength' hides global declaration
1>Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(146): error C4459: declaration of 'TraceLength' hides global declaration
1>Z:\TEMP\new\Source\sample_project\Routing\RouteManager.cpp(257): error C4459: declaration of 'TraceLength' hides global declaration
1>C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command ""C:\Program Files\Epic Games\UE_5.3\Engine\Build\BatchFiles\Build.bat" sample_projectEditor Win64 Development -Project="Z:\TEMP\new\sample_project.uproject" -WaitMutex -FromMsBuild" exited with code 6.
1> 0 Warning(s)
1> 4 Error(s)
1>
1>Time Elapsed 00:00:05.51
========== Build: 0 succeeded, 1 failed, 10 up-to-date, 0 skipped ==========
========== Build completed at 00:41 and took 06.048 seconds ==========
and error list:
I am stuck and can't do anything..
Does anybody have any hint on how to get it working?
Many thanks,
Luigi
This should now be resolved in the main branch as well. So you can simply pull the main branch or get a new copy of the Samples repo. Let us know if you are still having issues with this.
.NET desktop development
Desktop development with C++
Universal Windows Platform development
Game development with C++
C++ profiling tools
C++ AddressSanitizer
I can compile and open a new C++ project with the SDK 1.4 but not the sample_project..
I am able to compile in 5.1.1 but not 5.2.1 nor in 5.3.2
You can fix this by changing line 70 of "sample_project\Routing\RouteManager.cpp"
To one of the following option:
hi @AShahbaz and thank you for your reply.
I tried them all, one after the other, I cleaned the solution, built it, rebuilt and i am still getting the same errors.
I noticed that it works if I take the 3DAttribute folder out fo the Source folder, it builds and open.
This is the log but it looks similar to the previous one:
Build started at 17:03...
Restoring NuGet packages...
To prevent NuGet from restoring packages during build, open the Visual Studio Options dialog, click on the NuGet Package Manager node and uncheck 'Allow NuGet to download missing packages during build.'
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\EpicGames.IoHash.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\EpicGames.Serialization.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Redis\EpicGames.Redis.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\EpicGames.Horde.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\EpicGames.OIDC.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Scripts\AutomationScripts.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce\EpicGames.Perforce.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MongoDB\EpicGames.MongoDB.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\SteamDeck\SteamDeck.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\EpicGames.MsBuild.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce.Managed\EpicGames.Perforce.Managed.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Jupiter\EpicGames.Jupiter.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\EpicGames.Box.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.BuildGraph\EpicGames.BuildGraph.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\UE5ProgramRules\UE5ProgramRules.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\BuildGraph\BuildGraph.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Turnkey\Turnkey.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\MarketplaceRules\MarketplaceRules.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\SmartlingLocalization\SmartlingLocalization.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\CookedEditor\CookedEditor.Automation.csproj...
GET https://api.nuget.org/v3/vulnerabilities/index.json
OK https://api.nuget.org/v3/vulnerabilities/index.json 12ms
GET https://api.nuget.org/v3-vulnerabilities/2024.03.16.05.29.48/vulnerability.base.json
GET https://api.nuget.org/v3-vulnerabilities/2024.03.16.05.29.48/2024.03.18.05.30.02/vulnerability.update.json
OK https://api.nuget.org/v3-vulnerabilities/2024.03.16.05.29.48/vulnerability.base.json 27ms
OK https://api.nuget.org/v3-vulnerabilities/2024.03.16.05.29.48/2024.03.18.05.30.02/vulnerability.update.json 56ms
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MongoDB\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MongoDB\EpicGames.MongoDB.csproj (in 184 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Gauntlet\Gauntlet.Automation.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce\EpicGames.Perforce.csproj (in 191 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Jupiter\obj\project.assets.json
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\CrowdinLocalization\CrowdinLocalization.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Jupiter\EpicGames.Jupiter.csproj (in 195 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Apple\Apple.Automation.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\EpicGames.IoHash.csproj (in 201 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\obj\project.assets.json
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Android\Android.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\EpicGames.Box.csproj (in 205 ms).
Restoring packages for Z:\GARSDALE\arcgis_samples\sample_project\Intermediate\Build\BuildRulesProjects\sample_projectModuleRules\sample_projectModuleRules.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.BuildGraph\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.BuildGraph\EpicGames.BuildGraph.csproj (in 209 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce.Fixture\EpicGames.Perforce.Fixture.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\EpicGames.Serialization.csproj (in 215 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Oodle\EpicGames.Oodle.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Redis\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Redis\EpicGames.Redis.csproj (in 228 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\EpicGames.Core.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce.Managed\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Apple\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Gauntlet\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\CrowdinLocalization\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: Z:\GARSDALE\arcgis_samples\sample_project\Intermediate\Build\BuildRulesProjects\sample_projectModuleRules\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Android\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Oodle\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\EpicGames.Core.csproj (in 2 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\EpicGames.Build.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce.Managed\EpicGames.Perforce.Managed.csproj (in 234 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Apple\Apple.Automation.csproj (in 35 ms).
Restored Z:\GARSDALE\arcgis_samples\sample_project\Intermediate\Build\BuildRulesProjects\sample_projectModuleRules\sample_projectModuleRules.csproj (in 27 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Win\Win.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Oodle\EpicGames.Oodle.csproj (in 18 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Gauntlet\Gauntlet.Automation.csproj (in 48 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\CrowdinLocalization\CrowdinLocalization.Automation.csproj (in 41 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Plugins\ScriptPlugin\Source\ScriptGeneratorUbtPlugin\ScriptGeneratorUbtPlugin.ubtplugin.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\obj\project.assets.json
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Localization\Localization.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\AutomationUtils\AutomationUtils.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\LowLevelTests\LowLevelTests.Automation.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Plugins\ScriptPlugin\Source\ScriptGeneratorUbtPlugin\obj\project.assets.json
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\TVOS\TVOS.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Android\Android.Automation.csproj (in 31 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\UE5Rules\UE5Rules.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\EpicGames.Build.csproj (in 5 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\UnrealBuildTool.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\EpicGames.MsBuild.csproj (in 342 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\EpicGames.UHT.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Localization\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\LowLevelTests\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\TVOS\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\UE5Rules\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\CookedEditor\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\EpicGames.UHT.csproj (in 4 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Tracing\EpicGames.Tracing.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Localization\Localization.Automation.csproj (in 107 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Slack\EpicGames.Slack.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce.Fixture\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Tracing\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Slack\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Tracing\EpicGames.Tracing.csproj (in 1 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.AspNet\EpicGames.AspNet.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.AspNet\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\LowLevelTests\LowLevelTests.Automation.csproj (in 108 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\XLocLocalization\XLocLocalization.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Plugins\ScriptPlugin\Source\ScriptGeneratorUbtPlugin\ScriptGeneratorUbtPlugin.ubtplugin.csproj (in 1 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\OneSkyLocalization\OneSkyLocalization.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\UE5Rules\UE5Rules.csproj (in 107 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Mac\Mac.Automation.csproj...
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.AspNet\EpicGames.AspNet.csproj (in 3 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Perforce.Fixture\EpicGames.Perforce.Fixture.csproj (in 149 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Slack\EpicGames.Slack.csproj (in 1 ms).
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\IOS\IOS.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Linux\Linux.Automation.csproj...
Restoring packages for C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\AutomationTool.csproj...
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Mac\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\CookedEditor\CookedEditor.Automation.csproj (in 360 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Mac\Mac.Automation.csproj (in 22 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Win\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Linux\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\IOS\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\UE5ProgramRules\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\UnrealBuildTool.csproj (in 21 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\UE5ProgramRules\UE5ProgramRules.csproj (in 420 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Linux\Linux.Automation.csproj (in 16 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\IOS\IOS.Automation.csproj (in 17 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\TVOS\TVOS.Automation.csproj (in 109 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Win\Win.Automation.csproj (in 107 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Scripts\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Scripts\AutomationScripts.Automation.csproj (in 583 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\BuildGraph\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\BuildGraph\BuildGraph.Automation.csproj (in 638 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\SteamDeck\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\OneSkyLocalization\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\XLocLocalization\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\AutomationUtils\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\AutomationUtils\AutomationUtils.Automation.csproj (in 388 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\XLocLocalization\XLocLocalization.Automation.csproj (in 265 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\SteamDeck\SteamDeck.Automation.csproj (in 658 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\OneSkyLocalization\OneSkyLocalization.Automation.csproj (in 276 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\SmartlingLocalization\obj\project.assets.json
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\AutomationTool.csproj (in 354 ms).
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\SmartlingLocalization\SmartlingLocalization.Automation.csproj (in 736 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\EpicGames.Horde.csproj (in 772 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\MarketplaceRules\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Intermediate\Build\BuildRulesProjects\MarketplaceRules\MarketplaceRules.csproj (in 785 ms).
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\EpicGames.OIDC.csproj (in 797 ms).
1>------ Build started: Project: EpicGames.OIDC, Configuration: Development Any CPU ------
2>------ Build started: Project: EpicGames.Core, Configuration: Development Any CPU ------
Assets file has not changed. Skipping assets file writing. Path: C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Turnkey\obj\project.assets.json
Restored C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\AutomationTool\Turnkey\Turnkey.Automation.csproj (in 833 ms).
NuGet package restore finished.
1>Build started 18/03/2024 17:03:58.
2>Build started 18/03/2024 17:03:58.
2>Target _GenerateSourceLinkFile:
2> Source Link is empty, file 'obj\Development\net6.0\EpicGames.Core.sourcelink.json' does not exist.
1>Target _GenerateSourceLinkFile:
1> Source Link is empty, file 'obj\Development\net6.0\EpicGames.OIDC.sourcelink.json' does not exist.
1>Target CoreCompile:
1> CompilerServer: server - server processed compilation - 912b6a8e-983d-4c86-81d6-5e129c02ad38
1>Target _TouchLastBuildWithSkipAnalyzers:
1> Touching "obj\Development\net6.0\EpicGames.OIDC.csproj.BuildWithSkipAnalyzers".
1>Target CopyFilesToOutputDirectory:
1> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\obj\Development\net6.0\EpicGames.OIDC.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\bin\Development\net6.0\EpicGames.OIDC.dll".
1> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.OIDC.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\obj\Development\net6.0\ref\EpicGames.OIDC.dll".
1> EpicGames.OIDC -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\bin\Development\net6.0\EpicGames.OIDC.dll
1> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\obj\Development\net6.0\EpicGames.OIDC.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\bin\Development\net6.0\EpicGames.OIDC.pdb".
1>
1>Build succeeded.
1> 0 Warning(s)
1> 0 Error(s)
1>
1>Time Elapsed 00:00:01.50
2>Target CoreCompile:
2> CompilerServer: server - server processed compilation - 60f92a39-a5cf-455c-985b-afcf376b0e1b
2>Target _TouchLastBuildWithSkipAnalyzers:
2> Touching "obj\Development\net6.0\EpicGames.Core.csproj.BuildWithSkipAnalyzers".
2>Target CopyFilesToOutputDirectory:
2> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\obj\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll".
2> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\obj\Development\net6.0\ref\EpicGames.Core.dll".
2> EpicGames.Core -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll
2> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\obj\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb".
2>
2>Build succeeded.
2> 0 Warning(s)
2> 0 Error(s)
2>
2>Time Elapsed 00:00:04.30
3>------ Build started: Project: EpicGames.MsBuild, Configuration: Development Any CPU ------
4>------ Build started: Project: EpicGames.IoHash, Configuration: Development Any CPU ------
5>------ Build started: Project: EpicGames.Box, Configuration: Development Any CPU ------
5>Build started 18/03/2024 17:04:02.
4>Build started 18/03/2024 17:04:02.
3>Build started 18/03/2024 17:04:02.
5>Target _GetProjectReferenceTargetFrameworkProperties:
4>Target _GetProjectReferenceTargetFrameworkProperties:
5>Target ResolveProjectReferences:
3>Target _GetProjectReferenceTargetFrameworkProperties:
5>Target _GenerateSourceLinkFile:
5> Source Link is empty, file 'obj\Development\net6.0\EpicGames.Box.sourcelink.json' does not exist.
5>Target CoreCompile:
5> CompilerServer: server - server processed compilation - 67a2370f-38a7-46e1-aedb-329d199a1fed
5>Target _TouchLastBuildWithSkipAnalyzers:
5> Touching "obj\Development\net6.0\EpicGames.Box.csproj.BuildWithSkipAnalyzers".
5>Target _CopyFilesMarkedCopyLocal:
5> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Core.dll".
5> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Core.pdb".
5> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\obj\Development\net6.0\EpicGame.FDC1D7DF.Up2Date" because "AlwaysCreate" was specified.
5> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\obj\Development\net6.0\EpicGame.FDC1D7DF.Up2Date".
5>Target GetCopyToOutputDirectoryItems:
5> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
5>Target CopyFilesToOutputDirectory:
5> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\obj\Development\net6.0\EpicGames.Box.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.dll".
5> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.Box.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\ref\EpicGames.Box.dll".
5> EpicGames.Box -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.dll
5> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\obj\Development\net6.0\EpicGames.Box.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.pdb".
5> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\obj\Development\net6.0\EpicGames.Box.xml" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.xml".
5>
5>Build succeeded.
5> 0 Warning(s)
5> 0 Error(s)
5>
5>Time Elapsed 00:00:00.64
3>Target ResolveProjectReferences:
4>Target ResolveProjectReferences:
4>Target _GenerateSourceLinkFile:
4> Source Link is empty, file 'obj\Development\net6.0\EpicGames.IoHash.sourcelink.json' does not exist.
3>Target _GenerateSourceLinkFile:
3> Source Link is empty, file 'obj\Development\net6.0\EpicGames.MsBuild.sourcelink.json' does not exist.
4>Target CoreCompile:
4> CompilerServer: server - server processed compilation - c6ca16ce-b488-4978-89e2-07ed28d98274
4>Target _CopyFilesMarkedCopyLocal:
4> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.Core.pdb".
4> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.Core.dll".
4> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\obj\Development\net6.0\EpicGame.0C5877CF.Up2Date" because "AlwaysCreate" was specified.
4> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\obj\Development\net6.0\EpicGame.0C5877CF.Up2Date".
4>Target GetCopyToOutputDirectoryItems:
4> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
4>Target CopyFilesToOutputDirectory:
4> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\obj\Development\net6.0\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll".
4> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\obj\Development\net6.0\ref\EpicGames.IoHash.dll".
4> EpicGames.IoHash -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll
4> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\obj\Development\net6.0\EpicGames.IoHash.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.pdb".
4>
4>Build succeeded.
4> 0 Warning(s)
4> 0 Error(s)
4>
4>Time Elapsed 00:00:01.50
6>------ Build started: Project: EpicGames.Serialization, Configuration: Development Any CPU ------
6>Build started 18/03/2024 17:04:04.
6>Target _GetProjectReferenceTargetFrameworkProperties:
6>Target ResolveProjectReferences:
6>Target _GenerateSourceLinkFile:
6> Source Link is empty, file 'obj\Development\net6.0\EpicGames.Serialization.sourcelink.json' does not exist.
6>Target CoreCompile:
6> CompilerServer: server - server processed compilation - 550a7b65-5d97-4844-a39e-10a8a8074aa2
6>Target _TouchLastBuildWithSkipAnalyzers:
6> Touching "obj\Development\net6.0\EpicGames.Serialization.csproj.BuildWithSkipAnalyzers".
6>Target _CopyFilesMarkedCopyLocal:
6> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Core.pdb".
6> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.IoHash.pdb".
6> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Core.dll".
6> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.IoHash.dll".
6> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\obj\Development\net6.0\EpicGame.13665197.Up2Date" because "AlwaysCreate" was specified.
6> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\obj\Development\net6.0\EpicGame.13665197.Up2Date".
6>Target GetCopyToOutputDirectoryItems:
6> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
6>Target CopyFilesToOutputDirectory:
6> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\obj\Development\net6.0\EpicGames.Serialization.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.dll".
6> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.Serialization.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\obj\Development\net6.0\ref\EpicGames.Serialization.dll".
6> EpicGames.Serialization -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.dll
6> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\obj\Development\net6.0\EpicGames.Serialization.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.pdb".
6>
6>Build succeeded.
6> 0 Warning(s)
6> 0 Error(s)
6>
6>Time Elapsed 00:00:01.00
7>------ Build started: Project: EpicGames.Horde, Configuration: Development Any CPU ------
7>Build started 18/03/2024 17:04:05.
7>Target _GetProjectReferenceTargetFrameworkProperties:
7>Target ResolveProjectReferences:
7>Target _GenerateSourceLinkFile:
7> Source Link is empty, file 'obj\Development\net6.0\EpicGames.Horde.sourcelink.json' does not exist.
7>Target CoreCompile:
7> CompilerServer: server - server processed compilation - 8289056f-5e07-413c-83b7-081d7dac9278
7>Target _TouchLastBuildWithSkipAnalyzers:
7> Touching "obj\Development\net6.0\EpicGames.Horde.csproj.BuildWithSkipAnalyzers".
7>Target _CopyFilesMarkedCopyLocal:
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Core.dll".
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Serialization.dll".
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.IoHash.dll".
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Serialization.pdb".
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Core.pdb".
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.IoHash.pdb".
7> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\Development\net6.0\EpicGame.AF064860.Up2Date" because "AlwaysCreate" was specified.
7> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\Development\net6.0\EpicGame.AF064860.Up2Date".
7>Target GetCopyToOutputDirectoryItems:
7> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
7>Target CopyFilesToOutputDirectory:
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\Development\net6.0\EpicGames.Horde.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.dll".
7> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.Horde.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\Development\net6.0\ref\EpicGames.Horde.dll".
7> EpicGames.Horde -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.dll
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\Development\net6.0\EpicGames.Horde.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.pdb".
7> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\obj\Development\net6.0\EpicGames.Horde.xml" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.xml".
7>
7>Build succeeded.
7> 0 Warning(s)
7> 0 Error(s)
7>
7>Time Elapsed 00:00:02.80
3>Target CoreCompile:
3> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\CsProjBuilder.cs(249,8,249,20): warning CA2200: Re-throwing caught exception changes stack information (https://learn.microsoft.com/dotnet/fundamentals/code-analysis/quality-rules/ca2200)
3> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\CsProjBuilder.cs(305,10,305,72): warning CA2249: Use 'string.Contains' instead of 'string.IndexOf' to improve readability (https://learn.microsoft.com/dotnet/fundamentals/code-analysis/quality-rules/ca2249)
3> CompilerServer: server - server processed compilation - 18634f7d-7047-47ad-bd62-6324ac611562
3>Done building target "CoreCompile" in project "EpicGames.MsBuild.csproj".
3>Target _CopyFilesMarkedCopyLocal:
3> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.Core.pdb".
3> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.Core.dll".
3> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\obj\Development\net6.0\EpicGame.CE5A2AC0.Up2Date" because "AlwaysCreate" was specified.
3> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\obj\Development\net6.0\EpicGame.CE5A2AC0.Up2Date".
3>Target GetCopyToOutputDirectoryItems:
3> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
3>Target CopyFilesToOutputDirectory:
3> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\obj\Development\net6.0\EpicGames.MsBuild.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.dll".
3> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.MsBuild.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\ref\EpicGames.MsBuild.dll".
3> EpicGames.MsBuild -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.dll
3> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\obj\Development\net6.0\EpicGames.MsBuild.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.pdb".
3>
3>Done building project "EpicGames.MsBuild.csproj".
3>
3>Build succeeded.
3>
3>C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\CsProjBuilder.cs(249,8,249,20): warning CA2200: Re-throwing caught exception changes stack information (https://learn.microsoft.com/dotnet/fundamentals/code-analysis/quality-rules/ca2200)
3>C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\CsProjBuilder.cs(305,10,305,72): warning CA2249: Use 'string.Contains' instead of 'string.IndexOf' to improve readability (https://learn.microsoft.com/dotnet/fundamentals/code-analysis/quality-rules/ca2249)
3> 2 Warning(s)
3> 0 Error(s)
3>
3>Time Elapsed 00:00:10.85
8>------ Build started: Project: EpicGames.Build, Configuration: Development Any CPU ------
8>Build started 18/03/2024 17:04:13.
8>Target _GetProjectReferenceTargetFrameworkProperties:
8>Target ResolveProjectReferences:
8>Target _GenerateSourceLinkFile:
8> Source Link is empty, file 'obj\Development\net6.0\EpicGames.Build.sourcelink.json' does not exist.
8>Target CoreCompile:
8> CompilerServer: server - server processed compilation - 2a6f1462-9389-40b2-b694-79074e7ed393
8>Target _TouchLastBuildWithSkipAnalyzers:
8> Touching "obj\Development\net6.0\EpicGames.Build.csproj.BuildWithSkipAnalyzers".
8>Target _CopyFilesMarkedCopyLocal:
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Core.dll".
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.IoHash.pdb".
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.IoHash.dll".
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.MsBuild.pdb".
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Core.pdb".
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.MsBuild.dll".
8> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\obj\Development\net6.0\EpicGame.CA7482E4.Up2Date" because "AlwaysCreate" was specified.
8> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\obj\Development\net6.0\EpicGame.CA7482E4.Up2Date".
8>Target GetCopyToOutputDirectoryItems:
8> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
8>Target CopyFilesToOutputDirectory:
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\obj\Development\net6.0\EpicGames.Build.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.dll".
8> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.Build.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\ref\EpicGames.Build.dll".
8> EpicGames.Build -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.dll
8> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\obj\Development\net6.0\EpicGames.Build.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.pdb".
8>
8>Build succeeded.
8> 0 Warning(s)
8> 0 Error(s)
8>
8>Time Elapsed 00:00:01.29
9>------ Build started: Project: EpicGames.UHT, Configuration: Development Any CPU ------
9>Build started 18/03/2024 17:04:14.
9>Target _GetProjectReferenceTargetFrameworkProperties:
9>Target ResolveProjectReferences:
9>Target _GenerateSourceLinkFile:
9> Source Link is empty, file 'obj\Development\net6.0\EpicGames.UHT.sourcelink.json' does not exist.
9>Target CoreCompile:
9> CompilerServer: server - server processed compilation - e5f27512-317f-4963-a40a-765ed6b685a2
9>Target _TouchLastBuildWithSkipAnalyzers:
9> Touching "obj\Development\net6.0\EpicGames.UHT.csproj.BuildWithSkipAnalyzers".
9>Target _CopyFilesMarkedCopyLocal:
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.MsBuild.dll".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.Build.pdb".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.IoHash.dll".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.Build.dll".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.Core.pdb".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.Core.dll".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.IoHash.pdb".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.MsBuild.pdb".
9> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\obj\Development\net6.0\EpicGame.A76F72B3.Up2Date" because "AlwaysCreate" was specified.
9> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\obj\Development\net6.0\EpicGame.A76F72B3.Up2Date".
9>Target GetCopyToOutputDirectoryItems:
9> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
9>Target CopyFilesToOutputDirectory:
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\obj\Development\net6.0\EpicGames.UHT.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.dll".
9> Copying reference assembly from "obj\Development\net6.0\refint\EpicGames.UHT.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\ref\EpicGames.UHT.dll".
9> EpicGames.UHT -> C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.dll
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\obj\Development\net6.0\EpicGames.UHT.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.pdb".
9> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\obj\Development\net6.0\EpicGames.UHT.xml" to "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.xml".
9>
9>Build succeeded.
9> 0 Warning(s)
9> 0 Error(s)
9>
9>Time Elapsed 00:00:02.33
10>------ Build started: Project: UnrealBuildTool, Configuration: Development Any CPU ------
10>Build started 18/03/2024 17:04:17.
10>Target _GetProjectReferenceTargetFrameworkProperties:
10> Target GetTargetFrameworksWithPlatformForSingleTargetFramework:
10>Target ResolveProjectReferences:
10>Target _GenerateSourceLinkFile:
10> Source Link is empty, file 'obj\Development\UnrealBuildTool.sourcelink.json' does not exist.
10>Target CoreCompile:
10> CompilerServer: server - server processed compilation - 41bae713-e017-4a9f-b1da-cf38a27fa408
10>Target _TouchLastBuildWithSkipAnalyzers:
10> Touching "obj\Development\UnrealBuildTool.csproj.BuildWithSkipAnalyzers".
10>Target _CopyFilesMarkedCopyLocal:
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Box.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Build.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Horde.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Core.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.MsBuild.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.IoHash.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Serialization.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\bin\Development\net6.0\EpicGames.OIDC.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.OIDC.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.UHT.dll".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.xml" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Box.xml".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Box\bin\Development\net6.0\EpicGames.Box.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Box.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Build\bin\Development\net6.0\EpicGames.Build.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Build.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Core\bin\Development\net6.0\EpicGames.Core.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Core.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Horde.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Horde\bin\Development\net6.0\EpicGames.Horde.xml" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Horde.xml".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.IoHash\bin\Development\net6.0\EpicGames.IoHash.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.IoHash.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.OIDC\bin\Development\net6.0\EpicGames.OIDC.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.OIDC.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.Serialization\bin\Development\net6.0\EpicGames.Serialization.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.Serialization.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.UHT.pdb".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.UHT\bin\Development\net6.0\EpicGames.UHT.xml" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.UHT.xml".
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\Shared\EpicGames.MsBuild\bin\Development\net6.0\EpicGames.MsBuild.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\EpicGames.MsBuild.pdb".
10> Creating "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\Development\UnrealBu.51962A7B.Up2Date" because "AlwaysCreate" was specified.
10> Touching "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\Development\UnrealBu.51962A7B.Up2Date".
10>Target GetCopyToOutputDirectoryItems:
10> Target _GetCopyToOutputDirectoryItemsFromTransitiveProjectReferences:
10>Target _CopyOutOfDateSourceItemsToOutputDirectory:
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\Development\apphost.exe" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.exe".
10>Target _CopyAppConfigFile:
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\Development\UnrealBuildTool.dll.config" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll.config".
10>Target CopyFilesToOutputDirectory:
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\Development\UnrealBuildTool.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll".
10> Copying reference assembly from "obj\Development\refint\UnrealBuildTool.dll" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\ref\UnrealBuildTool.dll".
10> UnrealBuildTool -> C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll
10> Copying file from "C:\Program Files\Epic Games\UE_5.3\Engine\Source\Programs\UnrealBuildTool\obj\Development\UnrealBuildTool.pdb" to "C:\Program Files\Epic Games\UE_5.3\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.pdb".
10>
10>Build succeeded.
10> 0 Warning(s)
10> 0 Error(s)
10>
10>Time Elapsed 00:00:02.87
11>------ Build started: Project: sample_project, Configuration: Development_Editor x64 ------
11>Build started 18/03/2024 17:04:20.
11>Target Build:
11> Using bundled DotNet SDK version: 6.0.302
11> Running UnrealBuildTool: dotnet "..\..\Engine\Binaries\DotNET\UnrealBuildTool\UnrealBuildTool.dll" sample_projectEditor Win64 Development -Project="Z:\GARSDALE\arcgis_samples\sample_project\sample_project.uproject" -WaitMutex -FromMsBuild
11> Log file: C:\Users\info\AppData\Local\UnrealBuildTool\Log.txt
11> Creating makefile for sample_projectEditor (no existing makefile)
11> Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\ArcGISMapsSDK.uplugin : warning : Unknown platform HoloLens while parsing allow list for module descriptor ArcGISMapsSDK
11> Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\ArcGISMapsSDK.uplugin : warning : Unknown platform HoloLens while parsing allow list for module descriptor ArcGISSamples
11> DEPRECATION: 'IniKeyBlacklist', which is a config key in section [/Script/UnrealEd.ProjectPackagingSettings], in 'Z:\GARSDALE\arcgis_samples\sample_project\Config\DefaultGame.ini', has been deprecated. Using 'IniKeyDenylist' instead. It is recommended you update your .ini files as soon as possible, and replace IniKeyBlacklist with IniKeyDenylist
11> DEPRECATION: 'IniSectionBlacklist', which is a config key in section [/Script/UnrealEd.ProjectPackagingSettings], in 'Z:\GARSDALE\arcgis_samples\sample_project\Config\DefaultGame.ini', has been deprecated. Using 'IniSectionDenylist' instead. It is recommended you update your .ini files as soon as possible, and replace IniSectionBlacklist with IniSectionDenylist
11> Parsing headers for sample_projectEditor
11> Running Internal UnrealHeaderTool Z:\GARSDALE\arcgis_samples\sample_project\sample_project.uproject Z:\GARSDALE\arcgis_samples\sample_project\Intermediate\Build\Win64\sample_projectEditor\Development\sample_projectEditor.uhtmanifest -WarningsAsErrors -installed
11> Total of 0 written
11> Reflection code generated for sample_projectEditor in 0.8050898 seconds
11> Building sample_projectEditor...
11> Using Visual Studio 2022 14.38.33135 toolchain (C:\Program Files (x86)\Microsoft Visual Studio\2022\BuildTools\VC\Tools\MSVC\14.38.33130) and Windows 10.0.22621.0 SDK (C:\Program Files (x86)\Windows Kits\10).
11> [Upgrade]
11> [Upgrade] Using backward-compatible build settings. The latest version of UE sets the following values by default, which may require code changes:
11> [Upgrade] bLegacyParentIncludePaths = false => Omits module parent folders from include paths to reduce compiler command line length. (Previously: true).
11> [Upgrade] CppStandard = CppStandardVersion.Default => Updates C++ Standard to C++20 (Previously: CppStandardVersion.Cpp17).
11> [Upgrade] WindowsPlatform.bStrictConformanceMode = true => Updates MSVC strict conformance mode to true (Previously: false).
11> [Upgrade] Suppress this message by setting 'DefaultBuildSettings = BuildSettingsVersion.V4;' in sample_projectEditor.Target.cs, and explicitly overriding settings that differ from the new defaults.
11> [Upgrade]
11> [Upgrade]
11> [Upgrade] Using backward-compatible include order. The latest version of UE has changed the order of includes, which may require code changes. The current setting is:
11> [Upgrade] IncludeOrderVersion = EngineIncludeOrderVersion.Unreal5_0
11> [Upgrade] Suppress this message by setting 'IncludeOrderVersion = EngineIncludeOrderVersion.Latest;' in sample_projectEditor.Target.cs.
11> [Upgrade] Alternatively you can set this to 'EngineIncludeOrderVersion.Latest' to always use the latest include order. This will potentially cause compile errors when integrating new versions of the engine.
11> [Upgrade]
11> Determining max actions to execute in parallel (14 physical cores, 20 logical cores)
11> Executing up to 14 processes, one per physical core
11> ------ Building 36 action(s) started ------
11> [1/36] Resource Resource.rc
11> [2/36] Resource Resource.rc
11> [3/36] Resource Resource.rc
11> [4/36] Resource Default.rc2
11> [5/36] Compile [x64] PCH.ArcGISMapsSDKEditor.cpp
11> [6/36] Compile [x64] PCH.ArcGISSamples.cpp
11> [7/36] Compile [x64] PCH.ArcGISMapsSDK.cpp
11> [8/36] Compile [x64] Module.ArcGISMapsSDK.15.cpp
11> [9/36] Compile [x64] Module.ArcGISMapsSDK.5.cpp
11> [10/36] Compile [x64] Module.ArcGISMapsSDK.9.cpp
11> [11/36] Compile [x64] Module.ArcGISMapsSDK.6.cpp
11> [12/36] Compile [x64] Module.ArcGISMapsSDK.4.cpp
11> [13/36] Compile [x64] Module.ArcGISMapsSDK.2.cpp
11> [14/36] Compile [x64] Module.ArcGISMapsSDK.3.cpp
11> [15/36] Compile [x64] Module.ArcGISMapsSDK.12.cpp
11> [16/36] Compile [x64] Module.ArcGISSamples.cpp
11> [17/36] Link [x64] UnrealEditor-ArcGISSamples.lib
11> Creating library Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISSamples\UnrealEditor-ArcGISSamples.lib and object Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISSamples\UnrealEditor-ArcGISSamples.exp
11> [18/36] Compile [x64] Module.ArcGISMapsSDK.13.cpp
11> [19/36] Compile [x64] Module.ArcGISMapsSDK.1.cpp
11> [20/36] Compile [x64] Module.ArcGISMapsSDK.8.cpp
11> [21/36] Compile [x64] Module.ArcGISMapsSDK.11.cpp
11> [22/36] Compile [x64] Module.ArcGISMapsSDK.14.cpp
11> [23/36] Compile [x64] Module.ArcGISMapsSDK.10.cpp
11> [24/36] Compile [x64] Module.ArcGISMapsSDK.7.cpp
11> [25/36] Compile [x64] SharedPCH.Engine.Cpp17.InclOrderUnreal5_0.cpp
11> [26/36] Compile [x64] Module.sample_project.cpp
11> Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Routing\RouteManager.cpp(70): error C4459: declaration of 'TraceLength' hides global declaration
11> Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Measure\Measure.cpp(20): note: see declaration of 'TraceLength'
11> Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Routing\RouteManager.cpp(146): error C4459: declaration of 'TraceLength' hides global declaration
11> Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Routing\RouteManager.cpp(257): error C4459: declaration of 'TraceLength' hides global declaration
11> [27/36] Compile [x64] Module.ArcGISMapsSDKEditor.cpp
11> [28/36] Link [x64] UnrealEditor-ArcGISMapsSDKEditor.lib
11> Creating library Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDKEditor\UnrealEditor-ArcGISMapsSDKEditor.lib and object Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDKEditor\UnrealEditor-ArcGISMapsSDKEditor.exp
11> [29/36] Compile [x64] Module.ArcGISMapsSDK.16.cpp
11> [30/36] Link [x64] UnrealEditor-ArcGISMapsSDK.lib
11> Creating library Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDK\UnrealEditor-ArcGISMapsSDK.lib and object Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDK\UnrealEditor-ArcGISMapsSDK.exp
11> [31/36] Link [x64] UnrealEditor-ArcGISSamples.dll
11> Creating library Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISSamples\UnrealEditor-ArcGISSamples.sup.lib and object Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISSamples\UnrealEditor-ArcGISSamples.sup.exp
11> [32/36] Link [x64] UnrealEditor-ArcGISMapsSDKEditor.dll
11> Creating library Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDKEditor\UnrealEditor-ArcGISMapsSDKEditor.sup.lib and object Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDKEditor\UnrealEditor-ArcGISMapsSDKEditor.sup.exp
11> [33/36] Link [x64] UnrealEditor-ArcGISMapsSDK.dll
11> Creating library Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDK\UnrealEditor-ArcGISMapsSDK.sup.lib and object Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\Intermediate\Build\Win64\x64\UnrealEditor\Development\ArcGISMapsSDK\UnrealEditor-ArcGISMapsSDK.sup.exp
11> Total time in Parallel executor: 44.74 seconds
11> Total execution time: 48.98 seconds
11> C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command ""C:\Program Files\Epic Games\UE_5.3\Engine\Build\BatchFiles\Build.bat" sample_projectEditor Win64 Development -Project="Z:\GARSDALE\arcgis_samples\sample_project\sample_project.uproject" -WaitMutex -FromMsBuild" exited with code 6.
11>Done building target "Build" in project "sample_project.vcxproj" -- FAILED.
11>
11>Done building project "sample_project.vcxproj" -- FAILED.
11>
11>Build FAILED.
11>
11>Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\ArcGISMapsSDK.uplugin : warning : Unknown platform HoloLens while parsing allow list for module descriptor ArcGISMapsSDK
11>Z:\GARSDALE\arcgis_samples\sample_project\Plugins\ArcGISMapsSDK\ArcGISMapsSDK.uplugin : warning : Unknown platform HoloLens while parsing allow list for module descriptor ArcGISSamples
11>Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Routing\RouteManager.cpp(70): error C4459: declaration of 'TraceLength' hides global declaration
11>Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Routing\RouteManager.cpp(146): error C4459: declaration of 'TraceLength' hides global declaration
11>Z:\GARSDALE\arcgis_samples\sample_project\Source\sample_project\Routing\RouteManager.cpp(257): error C4459: declaration of 'TraceLength' hides global declaration
11>C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\Microsoft.MakeFile.Targets(44,5): error MSB3073: The command ""C:\Program Files\Epic Games\UE_5.3\Engine\Build\BatchFiles\Build.bat" sample_projectEditor Win64 Development -Project="Z:\GARSDALE\arcgis_samples\sample_project\sample_project.uproject" -WaitMutex -FromMsBuild" exited with code 6.
11> 2 Warning(s)
11> 4 Error(s)
11>
11>Time Elapsed 00:00:49.60
========== Build: 10 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
========== Build completed at 17:05 and took 01:13.123 minutes ==========
any other idea?
Not sure why the above suggestions won't work for you. They solved the issue for me locally. I also don't know why removing 3DAttributes helps, since it doesn't have any variable called TraceLength, which seems to be the issue.
If you are still having issues, there are a couple ideas you could try:
I know this is a weird one really... I am not very competent in C++ but I will try doing what you suggest.
Many thanks,
Luigi
Hi Luigi,
I'm going to add to what Arash mentioned above. There are 3 TraceLength Local Variables that need the fix he mentioned. In line 70, 146, and 257 of RouteManager.cpp, please change the line to be
"autoTraceLength = 10000000.f;". If this does not work, we currently have a fix up here that you can try. Simply switch your branch from main to "mas12517/FixRoutingSample", or download the zip for that branch off github and you should be able to go through the setup document as normal and everything should work. If you run into any other issues, please don't hesitate to reach out.
